FC parts, need them gone!
BRC
Postby BRC » Sun Jan 26, 2014 9:14
Got some leftover parts from the old motor still taking up prime garage real estate, they're collecting more dust than cash offers. I dont want to scrap them due to the hard to find nature of some of the parts so they're free!
I will not deliver, if your local to Colorado Springs I might be able to meet if im out for a cruise otherwise you must come and pick them up... preferably in a rotary of some sort ;)
S4 T2 dirveshaft (manual obviously, could use a coat of paint otherwise perfect)
S5 upper intake w/ throttle body and all sensors
S4 (i think) JDM lower intake (no EGR)
JDM OE top mouint intercooler (Says "Rotary")
S4 T2 coils (whole set w/ 8.8mm perf. wires)
S4 T2 Maf (with cone filter adapter plate)
Ill eventually have more but the rest is in storage, for now this is what I could easily find. As I said earlier the parts are free to any other rotary enthusiasts! Unfortunatly I will not "Hold" any of the parts for more than a couple days. Text me for any other info, Brett 7I9/322/443O
Brigdh
Postby Brigdh » Mon Jan 27, 2014 9:14
I'm not in the market for any of these, but you might want to figure out if the TMIC is S4 or S5, there are differences, and a FC coil is a FC coil - all FCs (S4, S5, Turbo, and NA) use the same stock coils (which are pretty much bullet proof unlike FD and RX-8 coils).
Good luck.
BRC
Postby BRC » Wed Jan 29, 2014 9:14
its an S5 top mount
Postby speedjunkie » Wed Jan 29, 2014 9:14
I'm gonna check with you on these parts right after you get rid of them.
2slw4u
Postby 2slw4u » Tue Feb 11, 2014 9:14
do you know if the s4 t2 drive shaft will work on the s5 t2?
vierte
Postby vierte » Tue Feb 11, 2014 9:14
It will work. I have a s5 tii tranny bolted to a s4 driveshaft, diff, and half shafts.
BRC
Postby BRC » Tue Feb 11, 2014 9:14
same way I had it ^
BRC
Postby BRC » Thu Feb 13, 2014 9:14
found an incomplete engine o-ring kit! its technically for an 86-88 N/A but the vast majority of the seals will work on all
contents
(N326-10-B71) red water jacket seals x4
(N326-10-B72) black water jacket seals x4
(0839-10-455) tension bolt seals x18
(N236-14-604) oil metering pump o-ring x2
(0813-10-555) rear stationary gear o-ring x1
(N3A1-10-B73) dowel pin o-ring x4
(N231-10-174) front cover o-ring x1
(9954-10-1105) front hub bolt o-ring x1
(9954-10-1601) oil filter stand o-rings x2
(9954-10-3501) crank angle sensor o-ring x1
(9954-10-1252) injector diffuser o-rings x6
(N326-13-112) exhaust manifold gasket x1
(N326-20-305) EGR gasket x1
(N378-40-305) exhaust pipe gasket x1
The kit is incomplete due to missing upper and lower intake gaskets, 1 exhaust manifold gasket, and front cover teflon o-ring. I think the kit ran about $200 after shipping when I got it. All parts are from Atkins Rotary. I'd take $80 for the kit.
Ive also got a few Pineapple Racing blockoff plates for the EGR, ACV, and OMP, they only fit S4 N/A, theyll go with the kit too.
BRC
Postby BRC » Sat Feb 15, 2014 9:14
Update------ All current parts gone and seal kit sold.
When I clean out storage ill post what parts I find again.
Users browsing this forum: Bing [Bot] and 60 guests
