rx7 not idling
gs-panda
rx7 not idling
Postby gs-panda » Sun Jan 05, 2014 9:14
So I did some work on the rx7 not to long ago follow by new seats, brakes, and hood. But most importantly the omp lines have been changed, but in doing so cause my car to die out. Now the 7 will not hold it idle it starts warms up a bit and dies...itll only hold idle of I gas it
vierte
Postby vierte » Thu Jan 09, 2014 9:14
You most likely have a vacuum leak. I see its been a few days since you posted, have you resolved it?
gs-panda
Postby gs-panda » Mon Jan 13, 2014 9:14
vierte wrote:You most likely have a vacuum leak. I see its been a few days since you posted, have you resolved it?
Nope but what the best way of finding the leak,I really want the car back on the road
D Walker
Postby D Walker » Mon Jan 13, 2014 9:14
If you want to swing it by the shop sometime I will be glad to look at it
Postby RX-7 Chris » Tue Jan 14, 2014 9:14
gs-panda wrote:Nope but what the best way of finding the leak,I really want the car back on the road
If you want to give me a call I can walk you through finding the leak.
alpha
Postby alpha » Tue Jan 14, 2014 9:14
I usually find leaks with a can of starting fluid (ether). If you spray near the air leak the engine will rev up.
Good luck panda!
Users browsing this forum: Baidu [Spider] and 79 guests
