DIY Digital Multi-Gauge
Just a teaser for now. Who would rock a digital multi-guage? 8 or so engine parameters with individually selectable gauges...
vierte wrote:Just a teaser for now. Who would rock a digital multi-guage? 8 or so engine parameters with individually selectable gauges...
Very nice. I use the Aeroforce Interceptor. Was happy with it until the Temp Sensor went out and the oil temp started reading wayyyy off. I Liked it but probably wouldn't recommend it. I'm thinking of switching to the PLX digital gauge this Spring. I have the digital gauge between my boost and oil pressure gauges. The scan gauge sees all my OBDII parameters and Wideband O2 and used to do my oil temp.
ahh yes. An OBD gauge would be great for the MSP.
This setup is going in an FD with no obd. Might try to implement a low oil pressure shutdown... I've known a couple people who have ruptured an oil cooler line either on the dyno or at the track and killed a motor.
This setup will do manifold pressure, fuel pressure, oil pressure, oil temp, coolant temp, intake temp,rpm, and air fuel ratio. All sensors will be stand alone sensors but might try to piggyback off some sensors like a GM Map sensors.
vierte wrote:ahh yes. An OBD gauge would be great for the MSP.
Yeah. Aeroforce and plx, have none OBDII versions. I think they can monitor like 4 parameters per gauge. You should look into the plx ones. Its expensive though.
The PLX DM6 is $90 and says you can daisy chain up to 16 sensors. Not 100% sure if that's with one gauge or more but you could buy this for most of the none essential stuff you want to monitor then get a couple of anolog ones next to it. I'll post a pic of my setup after work this afternoon.
There is my set up. Gong to replace the center Aeroforce with the PLX gauge. Bad picture I know. I had a crappy cell phone camera 5-6 yrs ago.
not too shaby! its always hard to find a good location for gauges it seems. Is that an aftermarket dash panel?
