idle air control sensor replacement
Andyscums
Postby Andyscums » Sun Nov 10, 2013 9:14
Has anyone done this?
I have read that it's in the throttle body and also that there isn't one. I had a cel and had the code pulled and it was an idle control sensor. Does anyone know if you can just clean the throttle body to fix this problem?
Any help is greatly appreciated
Autotech fuel internals, JBR egr delete, JBR throttle body gasket, eBay catless dp, cnt cat back, port and polished intake manifold, cxracing fmic, Cobb turbo inlet, cpe CAI, turbosmart BOV, corks port short shift plate, corksport 70mm shifter bushings
Users browsing this forum: Bing [Bot] and 131 guests
