Need exhaust work
Need exhaust work
Can anyone swap my old exhaust back on for dirt cheap? Its in 3 pieces and you'd have to cut the MS3 exhaust in half i think to get it off. Let me know asap please
SOLD 2004 Mazda3 hatch
2004 Java Black Pearl Forester XT
thats odd.. why would you have to cut it in half to take it off? it will have to be welded back together prior to installing it. I would offer my garage up.. but I don't currently have a welder.
- AuroraAxela
vierte wrote:thats odd.. why would you have to cut it in half to take it off? it will have to be welded back together prior to installing it. I would offer my garage up.. but I don't currently have a welder.
The stock exhausts on the mz3/ms3 go over the rear suspension crossmember. You would have to remove the crossmember to get it out in one piece. Aftermarket exhausts typically have dealt with this and made a join at that location, but either you cut the stock one, or you do tons of suspension work. *shrug*
lol..
or you could have a couple flanges welded on and just bolt it back up. I drove an rx7 with a 3" strait pipe.. and it attracted way too much of the attention!
kingtut wrote:I don't always do my own exhaust work... but when I do, I use an exhaust shop.
you sir.... are a wise man.
Yea that sounds about right. I had my stock catback welded back onto my MS3 after having 3" straight pipe and not being able to stand it for more than a week. The straight pipe catback was fine with the stock DP but once I put the catless DP on it was waaay too loud and didn't even sound good. Pretty sure they charged me around $80 to do it, including having to weld a little piece of spacer pipe in there over the axle because for some reason it was coming up short.
