BNR Upgrade for RX-8 Greddy Turbo.
Postby GR-8 » Wed May 29, 2013 9:14
Thought I's share and post up some pics. My turbo got back from BNR today. The did a great job. Made a nice bracket for the WG Actuator and gave me a new actuator as well. They cleaned the turbo and it looks like new. Better than when I bought it used. Should be installing it tomorrow after work. Dependimg how tired I am install may stretch into Friday.
BNR's custom compressor wheel upgrade
BNR custom water cooled bearing housing
upgraded thrust bearing assembly
11 blade turbine wheel upgrade
balanced to .5 gram/in2
All new CHRA (center housing rotating assembly)
Postby VRx8 » Wed May 29, 2013 9:14
I remember installing one of those greddy kit on my rx8! Jeez what a pain!
How much HP you can get out of that one?
VRx8 wrote:I remember installing one of those greddy kit on my rx8! Jeez what a pain!
It's a pain. But I've done it so many times now I'm a pro. BNR says I could probably make 320 before the restrictions of the IC become a problem. I was @ 248 WHP before I returned. 279 WHP on the tune before the turbo blew. That's on a dyno dynamics.
Mortose
Postby Mortose » Wed May 29, 2013 9:14
what kind of tq are you making? and what is your boost target?
Looking off the dyno sheet TQ is about 220-230. Just estimating that off the graph we didn't print the exact numbers for TQ. I was pushing 15psi.
Postby Number2 » Thu May 30, 2013 9:14
Good luck with the install Jimmy. I bet it is a PITA!
Postby GR-8 » Thu May 30, 2013 9:14
So far I got the exhaust off and everything upstairs taken apart. Just need to pull the exhaust manifold tomorrow and run the coolant lines for the turbo then pit it all back together. I started almost at 9 tomight.
Tomorrow will be fun. I have to go to the body shop and swap mufflers and the straight pipe out of the Grey one right after work. Will be in the garage all day after 5. Hopefully it all goes smooth putting the turbo and mani back on. That takes the longest.
REd88GTU
Postby REd88GTU » Thu May 30, 2013 9:14
looks good mane! cant wait to see it in person.
[color="Red"]88 Mazda Rx-7 GTU[/color] (SOLD)
94 Mazda Rx-7 Touring (Bolt-ons, catless turbo-back, PFC, Stance CO's, PF Supercars built and street ported,+99 Spec Twins)
[color="DarkRed"]94 Pontiac Firebird Formula[/color] (Bolt-ons, SOLD)
[color="DarkRed"]99 Nissan Pathfinder[/color] (VG33E, DD, in need of a supercharger)
