Electric fan problem
gs-panda
Postby gs-panda » Thu Dec 13, 2012 9:14
So last sunday I've got another rx7 but this time it's a 88 vert and i love it.I'll post pics later. So I have a minor problem with it and it is the fan. It's not the first time I've seen this type of setup but I think it's plain stupid to manually switch on the fan when the car is at a stop and getting heated. So that being said any tips on buying a new fan? Are univeral fans ok or what do I need to look for? I was told by my teacher to buy a kit on summit racing but I don't know which or what to look for.
Postby VRx8 » Thu Dec 13, 2012 9:14
Summit sells a kit that had a probe, you stick that in the radiator and it will turn on the fans automatic for you. Ideally you want to fix the problem the right way by letting the edu do it but if that can't be done them I'll go with a universal kit.
Postby RX-7 Chris » Thu Dec 13, 2012 9:14
on my old black car I had an electric fan setup.
I used this: http://www.summitracing.com/parts/prf-30102/overview/
You need the highest CFM fan possible for these cars. I actually used a 90-95 Taurus 3.8 fan. They are one of the best fans put in a car fron the factory and really easy to find.
vierte
Postby vierte » Thu Dec 13, 2012 9:14
These guys are right on. If you're on the stock ecu, you'll have to either build a temperature control circuit or buy one and install it. One thing I will add is one of the biggest flaws in most electric fan conversions is poor shrouding. The electric fan should draw air through the entire radiator.. not just the small round circle of the fan. Otherwise a large portion of the radiator is rejecting heat by conduction, free convection and radiation instead of forced convection.. Forced convection is by far more efficient.
gs-panda
RX-7 Chris wrote:on my old black car I had an electric fan setup.
Thanks Chris you always come through for me and I may just go with your setup
Postby RX-7 Chris » Fri Dec 14, 2012 9:14
I picked up the fan at the U Pull & Pay for $15. http://www.upullandpay.com/
Made sure you grab the plug with with about 6" of withing with it. It makes the install much easier.
I like the sensor setup better that the probe setup because you are getting a much better reading of temp of the motor. I ran an FC water pump so the setup would be basically the same. I installed sensor on the back side of the water pump housing. I can help you with the install.
gs-panda
Postby gs-panda » Fri Dec 14, 2012 9:14
RX-7 Chris wrote:I picked up the fan at the U Pull & Pay for $15. http://www.upullandpay.com/
I think it would be a good idea to get soon help to install it...so we have to meet up when I gather all the parts needed
Users browsing this forum: No registered users and 125 guests
