need help with timing Rx7 12a Turbo
boosted12a
Postby boosted12a » Sat Nov 17, 2012 9:14
i need help findin TDC of my 12a Turbo, engine was rebuild but the car wont start and it sounds funny while crankin it.
Postby RX-7 Chris » Mon Nov 19, 2012 9:14
I assume TDC is the same as a regular 12A. If you have a stock style flywheel you can pull the inspection plate on the passenger side and there is a mark on the flywheel that shows top dead center.
also the front pully keyway will be at 9:00. This is true for all rotaries.
boosted12a
Postby boosted12a » Mon Nov 19, 2012 9:14
yeah i was able to that and i installed the CAS (turbo 2 ignition) the car wont start , it sound that is about to start but it wont, i have fuel and spark.
boosted12a
Postby boosted12a » Sun Dec 23, 2012 9:14
got the engine running :D
Postby VRx8 » Sun Dec 23, 2012 9:14
What was it?
boosted12a
the CAS (distribuitor) was installed wrong i put the engine top dead center and installed the CAS the engine started right away
Postby RX-7 Chris » Wed Dec 26, 2012 9:14
glad you got it figured out.
vierte
Postby vierte » Wed Dec 26, 2012 9:14
Nice. Was going to offer my (lack of) expert opinion but it sounds like you figured it out! What are you using to control ignition on that thing? And is it carbed or fuel injected if you don't mind me asking? I saw a cool blow through carb setup recently and it got my interests perked.
boosted12a
Postby boosted12a » Wed Dec 26, 2012 9:14
vierte wrote:Nice. Was going to offer my (lack of) expert opinion but it sounds like you figured it out! What are you using to control ignition on that thing? And is it carbed or fuel injected if you don't mind me asking? I saw a cool blow through carb setup recently and it got my interests perked.
its fuel injected with turbo 2 ignition and a microtech ecu
Users browsing this forum: Baidu [Spider], Bing [Bot] and 161 guests
