Tuning help for those with PFC and Datalogit
Postby speedjunkie » Sun Aug 26, 2012 9:14
For those of you with a Power FC and a datalogit (I really don't feel like removing mine anymore lol), I am telling you now because I'm kicking myself really hard for not doing this before. Get a wideband if you don't have one, figure out how to wire it into the datalogit so you can log the data and don't try to tune like a freaking caveman like I have been the last several years. GOOD GRIEF! It's insane how easy it is to tune the fuel map now. Even without the spreadsheet it would be easier without having to watch the wideband and figure out what cells need to be changed.
I wish I'd done this years ago.
Rx7boy719
Postby Rx7boy719 » Sun Aug 26, 2012 9:14
Can this work on my wideband?
[font="Comic Sans MS"][SIZE="3"][color="Red"]My reaction when I got my first FD[/color][/SIZE][/font]:lol: Image
I imagine it will. You just gotta figure out how to wire it.
Postby Shadowden » Mon Aug 27, 2012 9:14
Unfortunately, due to Geico commercials, I now find the term caveman to be prejudice. :p
what additional information does the wideband provide you in your dataloggit output that made tuning easier?
I thought the car's ecu constantly worked to read the AFR and attempted to optimize it. If so, shouldn't the dtaloggit pick up the AFRs from the ecu? Please remember, I am completely new to cars, and don't turbo...
Postby chickenwafer » Mon Aug 27, 2012 9:14
It will work with any wideband that outputs a 0-5v signal. It speeds up tuning exponentially once you have a solid base map with good timing and correction tables to tune from.
Eric, I've also been telling you to do this for over a year lol
Shadowden wrote:Unfortunately, due to Geico commercials, I now find the term caveman to be prejudice. :p
New ECUs cam, such as factory ECUs, not the PowerFC which is an aftermarket standalone ECU that replaces the factory ECU. It doesn't have any kind of by intuitive WB02 sensor feedback, otherwise known as closed loop tuning.
Remember, the 3rd gen rx7 is an OBDI Car, so it doesn't have the mega processing power of the new cars. The factory ECU has an 8 bit processor! It does do some closed loop idle control, and so does the pfc, but that is also with an older narrow band 02 sensor, so it isn't as accurate or reliable as a wideband sensor.
Really, I could go on a for a long, long time on the differences. But the Datalogit is just a tuning interface for the standalone Pfc ECU, so no factory equipment remains.
Postby speedjunkie » Mon Aug 27, 2012 9:14
Yeah I know, I just figured it would be much more difficult than that lol. Hooking up the yellow wire and making a ground wire...really?! lol
Postby VRx8 » Mon Aug 27, 2012 9:14
Eric let me borrow your datalogit lol JK
Postby speedjunkie » Tue Aug 28, 2012 9:14
Now that it's wired in even more I wanna take it out even less. lol
boosted12a
Postby boosted12a » Tue Aug 28, 2012 9:14
hahaha i learn the hard way too no wideband in my car and i mess with the fuel settings end up blowing my engine at the track
Postby speedjunkie » Sat Sep 01, 2012 9:14
That'll do it lol.
