Considering selling one of the RX-8 race cars
D Walker
Postby D Walker » Tue May 29, 2012 9:14
Due to a potential space issue, we are considering selling one of our World Challenge RX-8s at the end of this season. The one most likely on the block will be the "#8" car-
-Built last season from a 2004light front-end hit
-SCCA PRO Racing chassis plate, Current SCCA/NASA Logbooks
-Fresh 2009-up Gearbox
-ACT Clutch, Puck Disc and Flywheel
-Ron Davis Radiator
-RB flashed ECU
-Dyno developed Intake
-Custom SS matched header and exhaust
-Mazdaspeed "Carbon"Strut Bar
-Mazdaspeed/Eibach dampers
-Three-piece hollow front sway bar
-Sparco EVO seat
-Sparco Steering wheel/NRG removable wheel hub
-Harnesses dated to 2016
-Right side net
-10lb fire system
-Wired for radio with cage mounted handset box and 1/4 wave antenna
-5:12 rear differential with limited slip
-hardwired transponder
-AIM XG Log Dash with beacon, Wired into the OBD2 port as well as having additional inputs.
Car weighs 2550lbs dry and is setup to run on 17X8 or 17X8.5F/17x9R wheels. Extremely well developed car and is setup specifically for sprint racing but can be easily prepped for endurance events. We just ran the car at Miller and JD managed a 4th and 5th place finish, DQ'ed due to ride height. Car has not been damaged since it build. All control arms, bushings, etc are in excellent condition or are replaced. Currently still in last seasons livery but will be in this years red/black colours if we run the car at Mid-Ohio and Sears Point. Car can be repainted prior to sale.
Thinking around 30K, will listen to reasonable offers and can include a Racekeeper with cameras, a chassis data system, etc. for additional cost, and some spares may be available. Test days for serious buyers can be easily arranged.
