Car won't start at all now..
christi
Postby christi » Sun Feb 19, 2012 9:14
So tell me this: How does your car battery and what seems alternator die when you use a portable battery charger to charge your battery after your car has been sitting for 2 months? Yeah. My rx-7 doesn't even turn on AT ALL now. NO dashboard lights, no nothing. Anyone have any ideas???
It did however start when we had it for a minute charged to another car via jumper cables. It did a few back fires then completely died. SO that's why I did the portable charger.....
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
Postby VRx8 » Sun Feb 19, 2012 9:14
does it crank?
D Walker
Postby D Walker » Sun Feb 19, 2012 9:14
If the battery is completely dead many battery chargers cannot produce enough amps to get the think to start, because its also trying to charge the battery. You can put a good battery on it and see if it starts, or try and charge your battery overnight and if it doesnt take a charge, its likely to need a replacement.
Postby chickenwafer » Sun Feb 19, 2012 9:14
Most batteries can't come back from being run very low. Get a fresh good new battery. If that still doesn't work check main fuses.
christi
Postby christi » Mon Feb 20, 2012 9:14
@VRx8: It won't crank at all. It's like you don't have a alternative and battery connected.
@Don & Chicken: Yeah. That's what I've been told lately. I'm probably just going to fork out the 80$ or so to buy a new battery. Any recommendations for a "good" battery?
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby RX-7 Chris » Mon Feb 20, 2012 9:14
interstate
High Flying 8
Postby High Flying 8 » Mon Feb 20, 2012 9:14
This may sound obvious, but it isn't always. Check and clean the ground connection on the battery and the negative cable for continuity. If it is not making a connection, nothing will work and it will not charge.
Do this before you go spending the money on a new battery. It doesn't cost anything.
you can also pull the battery out and take it to the parts store and they can test it for free.
christi
Postby christi » Thu Mar 01, 2012 9:14
yay! fixed the car, she runs, and the afm and tb have been installed, she still has a slight idle problem but eventually will even out after driven a while. Doesn't seem to over heat right now b ut then again it's the winter time and im in pueblo with no hills....
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby GR-8 » Thu Mar 01, 2012 9:14
Woooo! So was it the battery?
christi
It sure was!
13B n/a Street Port
Goopy performance
2005 Mazda 3
SecondGenPAt
Postby SecondGenPAt » Thu Mar 01, 2012 9:14
why was the tb replaced?
Hakuna Matata
pyrrhus17
Postby pyrrhus17 » Thu Mar 01, 2012 9:14
Glad to here it was something so simple . I am in pew town for the weekend helping my Dad recover from a triple bypass .So if you see us out in a new MSP3 honk . Man the wind in pueblo west was crazy last night !
christi
Good luck on the bypass on your father, Pyrr. I'm driving my RX-7 to and from work this week so I can avoid filling up the mazda 3. I'm usually seen on main street by AT&T.
Pat: It was originally not working properly anyway, per Don previously in posts and per other Pat. I had to take the idle screw ALL the way up (Don't you remember? haha) in order to keep idle....
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Postby christi » Sun Apr 08, 2012 9:14
Car doesn't start again. Battery is nearly 1 month 8 days old. I haven't driven her in 2 weeks - but that SHOULD NOT kill a battery? I have to have AutoZone re charge it, and test it again. I'm thinking since I don't drive the car much and up until I fix the OP gauge, I'm going to unhook the battery once we get this fixed.
My question is, would this be caused by a bad alternator to kill batteries so fast?
13B n/a Street Port
Goopy performance
2005 Mazda 3
