Thanks all...
2007 Mazda CX-7
P0401 EGR FLOW INSUFFICIENT
P2187 FUEL SYSTEM TOO RICH AT IDLE
P0455 EVAPORATIVE EMISSION SYSTEM LEAK DETECTED
RichB wrote:I know about these two:
P0401 EGR FLOW INSUFFICIENT = Your EGR is clogged and you need to clean it. You can run Seafoam or something through your engine but cleaning it manually is the best bet. The EGR gets dirty so freaking fast on this engine. There's a how-to on MSF.org in the MS3 section.
Thinking about doing the Seafoam treatment.....I have to do an emissions test before the end of the month.....
P0455 EVAPORATIVE EMISSION SYSTEM LEAK DETECTED = Your gas cap might be shot. I actually failed emissions because of it last year. I was so mad!
I replaced this once because of a faulty cap........might have to change it again...
For the P2187 I'd check the BPV. How is your set up (springs, shims, etc....)?
Blue...no shims.....
RichB wrote:Hmm. I thought you'd get a lean at idle code with the vacuum line popping off. Good to know.
rush24 wrote:Blue...no shims.....
erod550 wrote:You do get too lean at idle. P2187 is too lean. I think rush may have typo'd with the too rich description.
