Case angle sensor
Skye's7
Case angle sensor
Postby Skye's7 » Sun Jan 29, 2012 9:14
Alright, since no one on the rx7club can't answer a simple question without starting a fire, guess I'll try it here. How is the crank angle sensor adjusted? I know there is something involving a timing light and turning of something. What the guy before me discribed was what he called the distributor was replaced by him an set to where the marking was, but needs to be fine tuned. I don't know what to do. Should I just go and open the hood and just lossen the bolt and start turning things? Getting pretty frustrated. And also it's possible a vacuum leak
D Walker
Postby D Walker » Sun Jan 29, 2012 9:14
Remind me which generation? Adjusting the timing is well-doumented in the manual, but if you need some help swing by and I will help you out.
Don
Skye's7
Sounds good don. Only problem the car isn't registered, are you still located near bass pro? It's a 89 gxl
D Walker
no I am in Englewood
and an 89gxl should be no issue to get timed properly
SecondGenPAt
Postby SecondGenPAt » Sun Jan 29, 2012 9:14
Pretty easy. Just need a timing light, bridge the initial set coupler, or I guess in the case of an S5, ground the initial set coupler, and adjust the CAS to either the red or yellow mark on the Eccentric shaft pulley (depending on leading or trailing wire as reference)
Oh, and you do not "probably" have a vacuum leak. You have multiple vacuum leaks. It's an emission + Rotary thing. :D
Hakuna Matata
Postby ~Barn~ » Mon Jan 30, 2012 9:14
Call me crazy - and admittedly I know nothing of the subject - but everything that Pat just explained, sounds as if it could be entered into expert testimony.
G'luck with your issue Skye!
Image 720.935.6438
Postby RX-7 Chris » Mon Jan 30, 2012 9:14
if you need anymore detail, you can get the FSM here: http://foxed.ca/index.php?page=rx7manual
Skye's7
Postby Skye's7 » Sun Feb 12, 2012 9:14
Alright, so adjusting the CAS isn't to bad. The issues now is vacuum lines. So I got an idea of some of the lines but I still really have no idea of which is which
