I bought some used wheels from the junk yard, so far I have removed most of the paint but I can't remove the brake dust on the back. I've tried some cleaners but all they do is remove what plain soapy water would have removed anyway. any suggestions?
I have considerd paying to sand blast them then have them powder coated white. How much would I be spending if I did that? And where is a good cheap place near denver?
Un painting. Cleaning. Sand blasting. Powder coating. Alloy wheels
- AuroraAxela
Mineral spirits/solvent and a plastic-bristle scrub brush.
speedjunkie wrote:I would suggest sand blasting. However, my old boss who does powdercoating says he won't sandblast them if they're aluminum because it can weaken the wheel. I think that's what he said anyway, it's been a couple years haha. That would definitely get them clean though.
What about for alloy wheels. I believe alloy is a mixture of metals but I'm not sure. Some cleaning bottles mentioned to not us with alluminum or alloy so I wonder if they similar.
Do you have a number or business name where I can reach him at?
AuroraAxela wrote:Mineral spirits/solvent and a plastic-bristle scrub brush.
Thanks I'll look into that.
There is a place that does powder coating. I forgot the name but ill find it. He does good work. his shop is near Dons shop in Englewood. Good prices. They have a sandblasting guy they work with so they'll send it over to them. I think the price he gives you will include the price of sandblasting.
Pristine Powder Coating
1 (720) 488-5499
3768 South Lipan Street,
Englewood, CO 80110-3454
http://m.google.com/u/m/x893mO
1 (720) 488-5499
Here are some pictures.
taking them home
3 rims have been sprayed with paint remover
a few minutes after being sprayed
wiped off using a steel sponge. no scrubbing needed. some freckles remain. no big deal.
I finally found a good cleaner. I still need to scrub hard but nothing compared to having to hand sand them clean.
here is a picture to compare the before and after
left side of the rim is cleaned normally and the right side has been sanded after cleaning.
I have one rim still uncleaned. after i'm done I will sand all of them.
I emailed the guy Jimmy suggested and he said about 60$ a rim to lightly sand blast them and powder coat them in white. What do you guys think, is it worth it for stock rims? I want to stay conservative and not call any attention to the car, I could probably get some cheap knock off's for what I'm spending but I'd rather go oem then rice-oroni.
taking them home
I think that's a good price. Those rims are a much higher quality than any cheap knock off you could ever find. You would never have to worry about a rim breaking when you hit a bump while driving down the road.
So my opinion would be to stick with those.
That's what I was thinking too. rather get quality than "attractive" rims. I'm glad I have my steelies so I can take my time getting these rims perfect.
another question. when I get tires for them, will the tire shop f**k up the powder coat? if they do will I have a hard time getting them to pay for the repairs. I'm planning on going to peerless and getting new summer tires.
- AuroraAxela
Being a tire guy, I have had issues with this in the past. Some wheel-painting companies rush the baking part of the paint process, but this is less of a concern with you and they can take their time with your wheels because your car is not disabled. So a longer bake/cure time for the paint helps.
Please describe a cheap knock off wheel. Most replacement OEM wheels are in the 250+ price range. The mazda 3 wheel is listed at 237, though you can pick one up at 156 http://www.slickcar.com/details/10772-reproduction-wheels.asp
A lot of the Enkies are cheaper.
alex_n/a wrote:That's what I was thinking too. rather get quality than "attractive" rims. I'm glad I have my steelies so I can take my time getting these rims perfect.
The powder coating will be fine. The tire shop shouldn't damage the finish if they know what they are doing. $60 a wheel is a lot less then other places and that includes the sand blasting.
GR-8 wrote:There is a place that does powder coating. I forgot the name but ill find it. He does good work. his shop is near Dons shop in Englewood. Good prices. They have a sandblasting guy they work with so they'll send it over to them. I think the price he gives you will include the price of sandblasting.
1 (720) 488-5499
This guy did my wheels for $200 (the tires were unmounted from the wheels already). Included sandblasting, black gloss paint, and clearcoat.
Users browsing this forum: Bing [Bot] and 51 guests
