fs: few things not car related, and miata mazdaspeed sport exhaust.
Dange
Postby Dange » Fri Oct 14, 2011 9:14
I have a PSP 3000 for sale. in great condition. havent used since i got out of the military (was my field entertainment)
i havent used it since febuary so i figured i could use the money more than i can use this as a paperweight.
comes with psp3000
charger
3 games. god of war, assasis creed and ghost recon
2gb memory stick
$150obo
one tmaxx 4wd rc truck. faster than a jato/revo 50+mph
I have a t-maxx 2.5 I bought new when they first came out. got tired and it went into storage while i was in the military i got out and put a picco .26 conversion on to try and make it fun again and used it once in 6 months. my buddy has a revo with the os .18 swap and still couldnt keep up with this car.
it has the picco .26 properly broken in maybe 1 gallon total in the engine. including breakin.
mip sidepipe
pullstart conversion
rear spool from traxxas
RR twin disk slipper clutch with steel spur gear
RR vented bell gear.
machined 8mm aluminum chassis.
front and rear aluminum skidplates.
and a set of CVD axles and halfshafts still new in bag
ill include a gallon of fuel. with 2 tanks only used.
filler bottle
after run oil
air filter oil.
glow plug ignitor.
2 extra glowplugs.
and the stock traxxas radio
$350obo
i have a team losi minit i purchased in august since then I have put in a 8600kv brushless system. miniture synthesized reciever, full bearings to replace the plastic bushings. all aluminum shocks
Mip ball diff. and a team losi twin disk slipper. and a 9.6v cell 1500mah battery pack. i have a 7.2v batterypack as well somewhere but with the brushless system it dies almost immediately the mods alone cost more than I am asking you are basically getting the car free.
car probably does 50 or so with the current gears and battery. with a larger gearset and a 3cell lithium battery should be capable of 70mph. car already has issues keeping the front wheels on the ground. if cruising at half throttle (20 or so) and you pin the throttle it will get airborne.
and you cannot floor it from a stop othewise it ends up on its roof.
I have a mazdaspeed sports exahust for sale. no dents or leaks. I upgraded to a magnaflow exhaust 2-3 months after I got the car and this has been sitting in a box since.. and i dont see myself ever going back
it will sound great on an NA miata and provides more than enough flow for a greddy/16g/gt28 or smaller turbo setup
here is an NC miata with the dual outlet mazdaspeed sport exhaust. nb's should be pretty close. ignoring the difference in engine
http://youtu.be/OovwIUQ16Mo
150obo
Mazdaspeed springs. $150
mazda pulled these out of the mazdaspeed catalog and slapped them on the msm. they are great condition give approx 1 inch of drop. and are a massive improvement over stock miata springs.
these are currently in my garage in a box. if you want the sportvalved bilstiens (this combo with sways will put you at 0.98g on the skidpad vs the 0.90 stock) youll have to wait till i can get new coilovers. but they typically go for 300 as a combo on miata.net/msm forums. or ill sell you the H&R race springs and the SV bilstiens. 1.75" drop for say 75 bucks more? handling is way better. and Ill just sell the other set of springs separate.
04MSMGT
D Walker
Postby D Walker » Fri Oct 14, 2011 9:14
You know I am pretty interested in the PSP, you going to be in Denver anytime soon? Because I literally never get to the Springs
Dange
Postby Dange » Sun Oct 16, 2011 9:14
unfortunately im the same way. i dont really see myself going up there in the near future.
04MSMGT
borisovich
Postby borisovich » Sun Oct 16, 2011 9:14
if i would still have miata i would get the exhaust =)
Postby erod550 » Mon Oct 17, 2011 9:14
Exhaust is tempting. Does it need any modification to fit on an NA?
Dange
Postby Dange » Tue Oct 18, 2011 9:14
im not completely sure. i think the hangers MAY be different. it may not be a direct bolt up but nothing a muffler shop couldn't handle really easily(inexpensively).
04MSMGT
