rear:
front:
with current wheels/tires
the rear is about 2" higher than the back
iani1.1 wrote:not really, lowering springs dont really guarantee a drop unless you change out the strut. i mean, when you get after market struts the spring seat is usually lower than stock thus making actually seeing the difference.
if you do wanna go lower, id get coilovers or aftermarkets shock/struts with the ground control coils and camber plates
kyb gr2 with gf210 springs
[IMG http://i889.photobucket.com/albums/ac97 ... 132833.jpg[/IMG
coilovers
[sig below]
RX-7 Chris wrote:When I put springs on my car they said 3/4" lowering and they rased the car almost an 1".
erod550 wrote:It's also not uncommon for cars to just be higher in the rear than the front. So even though it might be lowered from stock, it could still be higher than the front. Like my Mustang. Stock springs/dampers, yet the rear sits higher than the front. In my case though, all the lowering springs advertise a bigger drop in the rear than in the front to level it out.
