so after doing some extensive research about the car and also talking to a few subie guys, i've finally decided the set up im going to go with it should put me around 300whp on revos dyno
intake-perrin cai
perrin tmic
bov-turbosmart dual port, or the perrin full recirc
fuel pump walsboro 255
750cc injectors so i can run e85
perrin crank pulley
perrin or cobb tbe...pretty close in price just want to see which one i can find in person to hear it
perrin turbo inlet hose
thers also more coming, but once i get the money after that stuff i should be good then for awhile
WRX mods coming
- reconbygod12
WRX mods coming
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
04 mazda 6s-gone
reconbygod12 wrote:so today i sold the speed 3...it was actually pretty tough to do, but it was time for a new car...so i bought a 2008 wrx sedan....i dont think i am going to mod the piss out of it like i did on the speed3...i figure l do a bov,intake and alot of suspension work....but i do have the ap for it and i think i have some other parts laying around the garage as well
- reconbygod12
- reconbygod12
- roninsoldier83
reconbygod12 wrote:so after doing some extensive research about the car and also talking to a few subie guys, i've finally decided the set up im going to go with it should put me around 300whp on revos dyno
intake-perrin cai
perrin tmic
perrin crank pulley
I have no idea who told you those mods on a 2008 TD04-13T powered WRX will put down 300whp on Revolutions Performance dyno, but unless something has changed drastically with their dyno (like converting to an uber-high reading Dynojet) or they're using an extremely high/overly inflated correction factor, a TD04 powered WRX has a snow balls chance in hell of hitting 300whp on their dyno, using their "half correction" factor (they use it specifically for turbo cars).
For reference, on E85 with full bolt-ons, STI's typically only make 265-280whp on that dyno. With a newer VF-series turbo or something along the lines of a 68HTA swap, you should be a lot closer to the 300whp on RP's dyno, but unless their dyno now reads significantly higher than it used to, I would be shocked if a TD04-powered WRX put down over ~240whp.... unless I'm missing something? Did RP get a new dyno/re-calibrate their old dyno/now use a higher correction factor that I don't know about? I haven't been there in over a year, so maybe I'm mistaken...
Just a thought: injectors are about the same price for those cars regardless of size (within <$100 of each other typically)... if you plan on running a larger turbo, I recommend you pickup a set of 850's to avoid maxing out the 750's when running corn gas. Also, like mentioned before, if you plan on running a larger turbo (>40 lb/min), it's a good idea to start saving for a new gearset or 6-speed swap.
Just my $.02
Mine: 2015 Subaru WRX
Hers: 2013 Subaru WRX
- reconbygod12
Looks like 300whp is possible with the 09 Turbo and E-85.
[ame="http://www.youtube.com/watch?v=_qyYG-lktkM"]YouTube - 2009 WRX E85 CONVERSION[/ame]
Apparently that guy is down in the Springs.
- Dange
learjet that dyno is at mac... as in he could read 300.
revos dyno dynamics is known as the heartbreak dyno. and reads really low. a stock STI that is rated at 300hp from the factory barely hits 205-210 on a good day at revos
my car back when i dynoed it would hit 180whp at revo but would reach around 225 hp at mac
04MSMGT
MAC also tends to use a ginormous correction factor, even on turbo cars. I have a dyno sheet saying my MS3 was putting down over 300whp when it was really only putting down 250whp (SAE correction factor was 1.21). So I bet that 09 WRX on E85 is still putting down much less than 300whp on Revo's dyno. My friend's stage 2 2011 STi only put down 250whp on it, even with their half correction factor.
- roninsoldier83
Learjet45 wrote:Looks like 300whp is possible with the 09 Turbo and E-85.
That's on MAC's much higher reading Dynojet... That car would not come close to putting down 300whp on Revo's Dyno Dynamics with their "half-correction" factor.
erod550 wrote:MAC also tends to use a ginormous correction factor, even on turbo cars. I have a dyno sheet saying my MS3 was putting down over 300whp when it was really only putting down 250whp (SAE correction factor was 1.21). So I bet that 09 WRX on E85 is still putting down much less than 300whp on Revo's dyno. My friend's stage 2 2011 STi only put down 250whp on it, even with their half correction factor.
While I agree with your statement per se, it's kind of a misnomer. On a Dyno Dynamics, it will compute what it believes to be a standard SAE correction factor based on conditions, and because there are too many factors for boosted cars (total pressure, compressor size/efficiency, ect) the SAE doesn't have a set figure for boosted cars. On a Dyno Dynamics, they can read the actual SAE correction and manipulate the figure to say whatever they want. For a boosted car Revolutions typically takes the SAE for that day and cuts it in half. Others like Harvey/Boost Creep just use a "flat" correction for boosted cars of 1.15 regardless of conditions; or at least he used to.
In contrast, the Dynojet MAC uses doesn't have the ability to manipulate the correction factor; their only real choices are on (SAE or other industry standard CF) or off per se. Which, typically when I've went to MAC in the past, they have printed out both. So they don't really use a "ginormous" correction factor, it's just standard SAE (which is in of itself an industry standard) which inflates what a boosted car at sea level would be putting down on the same type of dyno. For naturally aspirated cars, it's pretty accurate for what they should put down at sea level.... so it's not that they're trying to "trick" people per se (IMO); their dyno just doesn't have the ability to manipulate the CF like some other dynos do.
The point of a correction factor is only to try and show what your car should put down on the same type of dyno on a nice day/good conditions at sea level.
Although it really doesn't matter, as in my opinion a dyno should really only be used for a few very specific things:
-Tuning in a safe environment (vs. on the street)
-Showing gains or losses made via modifications and/or tuning.
-Helping to troubleshoot or diagnose issues, or at least quantifying an issue based on a loss of power.
-Comparing one vehicle's output to another vehicle's output on the SAME DYNO in similar/same conditions.
Anyone who uses it for anything else (i.e. e-pissing contests), or that thinks that all dynos read the same (LOL!) or that one of them is automatically "better" than another than another based on higher/lower output would be wise to educate themselves. Granted, certain types of dynos are better for things like partial throttle/load tuning *cough*load bearing*cough*, but that's a different discussion all in itself.
Yea I didn't mean to say that MAC was cheating on their numbers or anything, just that SAE correction of 1.21 is way too much on a boosted car. The SAE correction number of my Mustang stock, however, was pretty close to what stock cars are putting down at sea level, so it's fairly accurate for N/A cars. I was just commenting that it's easy to get a dyno reading that says 300whp even though your car isn't actually putting down anywhere near that.
Users browsing this forum: Google [Bot] and 114 guests
