Starting issue
Starting issue
I've been having some issues starting my Miata. It doesn't always start on the first try. A previous owner installed a push button start and when I push the button, sometimes I hear a click and a hum, but the car does not turn over. I have figured out that when this happens, if I push the button several times quickly it will finally catch and start up. I'm leaning toward a bad starter, as the Haynes manual says the starter's internal clutches could be slipping and the starter may need to be replaced. I'd like to fix the problem before I get stranded somewhere one day because it won't fire no matter how many times I hit the button. Any thoughts?
Sounds like what my starter was doing and mine turned out to be a bad starter. It is most likely a bad starter. I would also look at the battery cables.
sound can also be a relay. And the hum might be the fuel pump, and you are hearing it now because the engine cranking would cover up the noise. But I too think it's the starter.
well my teacher in collision repair said that would damage the starter even IF it was still good. He would tell me it is cheaper to remove it and have it tested at a parts store. Again. He was my collision repair teacher not mechanic so maybe he didn't know.
Yea that's what I figured. And it's only $60 after core return so it's not that expensive for a new one.
I don't think it's the battery connections or cables because it always clicks and I always have power when I turn the key.
Jeff, what's the easiest way to get at the starter? From the front right wheel well? Any tricks to getting that thing out of there? Looks to be pretty tight.
I have found in the past that many cars will click if the connections are bad. Basically, there is enough juice flowing to light everything up and enough to trigger the solenoid, but not the actual starter. Some simple corrosion on a battery terminal can be enough to do that. Best way to figure that out is to put cables on it. If some jumper cables get it to turn over right away, then it likely is the terminals. If not, then look at the starter. That is always my approach.
The starter is a bit of a PITA. There are 3 bolts that fit through the bell housing. To get to these you have to be under the car. Also the Miata has a bracket on the back that bolts to the block with a couple bolts. Those are reached from under the hood under the intake. Don't forget to un-plug the battery cables. 2 wires on the starter as well. Should come out through the bottom.
IF you get it tested, really all that means is that it worked at the time of the test. It could be an intermittent problem and test well. Just FYI.
Yea, a test isn't going to tell me much because it does work more than half the time. I'm just afraid one day it's going to quit even partially working and leave me stranded.
- I`m Batman
Yep, as long as I'm on a hill, although the Miata is so light even on flat ground I could probably run alongside it and get it moving enough.
Not exactly familliar with the Mazda starters, but "most" starters work by energizing the motor and to send the bendix (or drive gear) into the flywheel ring gear. It sounds to me that the thrust part of the bendix is sticky/gummed/gooey or otherwise not always thrusting. A clean job might get it fixed. I would double check the battery (including the starter) connections. If the connections send a partial amp load, it "could" spin the motor and not have enough left over to energize the mag coil to thrust the drive. If it were me, I'd just go for the new starter.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
2 Fords 29 & 2000.
99 BMW 328i
Users browsing this forum: No registered users and 145 guests
