brown coolant =(
borisovich
brown coolant =(
Postby borisovich » Thu Jun 16, 2011 9:14
so i just randomly checked my coolant today and it was dirty brown.... :eek: so i called a mechanic he said head gasket is blown, but some other mechanics just telling me do a flush and see what happens, ........ what should i do i got a person who can change head gasket for 300$ (labor) + parts...... if any body had that problem in their miata let me know plz =)
Postby iani1.1 » Thu Jun 16, 2011 9:14
hm, it just might be stop leak or residue of it. if its creamy brown its usually oil one of the signs of a blown head gasket. does the car blow white smoke consistantly? if not then you have nothing to worry about.
Postby dommo_g » Thu Jun 16, 2011 9:14
Check your oil for coolant contamination. It'll look like white stuff in your oil.
Postby erod550 » Fri Jun 17, 2011 9:14
Has your radiator turned brown? Over time Miata radiators will turn brown and need to be replaced. Might just need to replace the radiator and do a coolant flush and you'll be good.
borisovich
Postby borisovich » Fri Jun 17, 2011 9:14
hmm ill do coolant flush first and see wats up but thank you very much =)
Users browsing this forum: No registered users and 100 guests
