stallion breathes fire again
reconbygod12
Postby reconbygod12 » Fri Jun 03, 2011 9:14
sooo i did a boost leak test and i feel dumb i should've just went a little further to the turbo and see that my inlet was loose and yeah, but i took the boost controller off and put the stock one on...so what im asking does anyone know how to change the boost on the ap so i can go back to 21.5 psi
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby dommo_g » Fri Jun 03, 2011 9:14
Turbo inlet? As in intake to turbo connection?
Postby erod550 » Fri Jun 03, 2011 9:14
A loose turbo inlet would not cause a boost leak, though it could mess with your fuel trims a little. And I would strongly recommend against you trying to adjust your own tune in ATR.
reconbygod12
should i just put the mbc back on then
04 mazda 6s-gone
Postby chickenwafer » Fri Jun 03, 2011 9:14
Turbo inlet in constant vacuum and never sees boost. Most people pressure test their systems by removing the turbo inlet and putting a plug on the compressor inlet.
reconbygod12
they went through the sri and then he heard ti whisteling down there
04 mazda 6s-gone
Users browsing this forum: No registered users and 157 guests
