cutting carbon fiber
so, has anyone cut carbon fiber before?
Cobb–Access PORT
Cork Sport-FMIC,Intake,Inlet
Edge-Insight CS Scan Tool
Innovate-LC1 Wideband Gauge
Luminics-Fog,High Beams
RPM-Vent Pod
Turbo Smart-Dual Port BOV
Turbo XS-TBE[/SIZE]
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
Poet-Tek wrote:I cut it all the time working on molded RC Sailplanes. Is it cf cloth or a finished part? CF cloth you can cut with good scissors, a finished part you can usually cut with a Dremel and a good cutting wheel. Something super heavy, you might need a bandsaw.
it's a finished part and i have a dremal. i'll try that thanks
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
- reconbygod12
i use this. you can get one at homedepot or hobby lobby. treat the cf like plexiglass then use a blade or scissors to cut the remaining weave if there are some left. also its a little easier if its warm.
[ame="http://www.amazon.com/Red-Devil-1170-Plexiglass-Cutting/dp/B000BZZ1D0"]Amazon.com: Red Devil 1170 Plexiglass Cutting Tool: Home Improvement[/ame]
