So let's see if any CMZC folk can help me figure out how to fix this problem.
After I got home from the cruise today (yes, I was being dumb and stupid and retarded and just about every other word in the book) and didn't let my tires cool completely before checking the air pressure because my dad got another tire pressure checker thingy for the new Subaru. It was high, so I started letting some air out. Well, turns out the little thing on the tire that you press in to let the air out got stuck and I can't get it to stop. I'm down to 10 psi right now, so I need to try to figure this out to see if I can avoid having to put on the spare to go over to Firestone before school tomorrow to get it taken care of (I'm close enough to the gas station that I would feel fine driving on really low pressure as far as the gas station to put air in, like less than .3 miles, no driving on actual roads just through my neighborhood and into a shopping center). Any suggestions on what to try?
Issue with a tire
Issue with a tire
Hmm. I definitely wouldn't want to drive on a 10 PSI tire, but if it's holding 10 PSI, at least it's still sealed on the wheel. Assuming you don't have an air compressor with a tire filling bit, I guess I'd mount up the spare and drive the dismounted tire to a gas station with an air compressor and fill it right back up. You shouldn't need to go specifically to a tire place for that...
Learjet45 wrote:So let's see if any CMZC folk can help me figure out how to fix this problem.
After I got home from the cruise today (yes, I was being dumb and stupid and retarded and just about every other word in the book) and didn't let my tires cool completely before checking the air pressure because my dad got another tire pressure checker thingy for the new Subaru. I was high, so I started letting some air out. Well, turns out the little thing on the tire that you press in to let the air out got stuck and I can't get it to stop. I'm down to 10 psi right now, so I need to try to figure this out to see if I can avoid having to put on the spare to go over to Firestone before school tomorrow to get it taken care of (I'm close enough to the gas station that I would feel fine driving on really low pressure as far as the gas station to put air in, like less than .3 miles, no driving on actual roads just through my neighborhood and into a shopping center). Any suggestions on what to try?
First off don't be high! LOL! This happened to my sister and I just poked at the stem, "little thing on the tire that you press in...," till it popped back out. If it slowly keeps losing air you may just need a new stem.
It's only holding air when the little cap is on the end of the valve thing, and as soon as it's the least bit loose, it will be start leaking again. I'm not sure what it was at once completely cooled off this afternoon, but it could or couldn't have lost air since then. I was at about 35psi when still warm and got stuck and started leaking, and it was at about 25 or so when I got out a bit ago to check when the light was on. Between fumbling to get the cap back on and checking the pressure one last time before putting the cap on, I was down to 10.
I need to take it to Firestone to have them fix it so it stops leaking when the cap isn't fully secured if I can't figure it out.
I was trying to poke at the stem again with the pressure checker thingy, but I couldn't get it with that. I tried a skewer with a pointed tip and couldn't get it earlier this afternoon. The stem thing looked a bit crooked when checking earlier, so it might be the stem...
- Hschlick84
You sure type a lot of shit just to say 'my valve stem core is stuck'. Do you have any way at all to fill the tire at home? If not, go put about 50 psi in it to see if it'll pop that core back into place. If not, you'll have to take the core out and possibly replace it if it's bad and can't be cleaned. If you have a bottle of tire slime, the cap has a built in core remover tool. You can figure it out from there probably.
dommo_g wrote:You sure type a lot of shit just to say 'my valve stem core is stuck'. Do you have any way at all to fill the tire at home? If not, go put about 50 psi in it to see if it'll pop that core back into place. If not, you'll have to take the core out and possibly replace it if it's bad and can't be cleaned. If you have a bottle of tire slime, the cap has a built in core remover tool. You can figure it out from there probably.
Well excuse me for not knowing the exact technical term being that I haven't even been driving on my own for a year yet. Not to mention that even if I knew the proper term, I wouldn't have been sure if that was the issue.
No, I don't have any way to fill the tire at home.
And I'd rather just stick the spare on and take it to Firestone and tell them to fix it instead of trying to put 50psi of air in it to see whether that fixes it or not.
- Hschlick84
Learjet45 wrote:Well excuse me for not knowing the exact technical term being that I haven't even been driving on my own for a year yet. Not to mention that even if I knew the proper term, I wouldn't have been sure if that was the issue.
And I'd rather just stick the spare on and take it to Firestone and tell them to fix it instead of trying to put 50psi of air in it.
You can purchase a cheap 12 volt air compressor for less than $60 at Sears or some type of hardware store. Worked for me and could work for you, just saying. It's about the size of stacking three hardcover books together, convienient and portable.
I could, but I wouldn't use it often enough to justify spending $60 on it. Not worth it to me imo. I'd rather go put $1 in the air compressor at the gas station and put air in when I need to.
um, why'd you take let the air out the in first place?
get one of these (valve core tool). you can get one at your local parts store or whatever
[ame="http://www.amazon.com/Klein-Tools-32527-Screwdriver-Driver/dp/B003WVMAKC"]Amazon.com: Klein Tools 32527 11-In-1 Screwdriver/Nut Driver - Schrader® Valve Core Tool: Home Improvement[/ame]
unscrew the the valve core, steal your neighbors or someone elses if its bad then install the new one. saved yourself $60. profit
35psi when warm isn't high. Even when cold that's not that high.
Dammit Johnathan I just bought you this car yesterday and you already broke it?!!!!11!!!-!!
I imagine that was what your dad said lol also just take the wheel off and roll it to the nearest gas station if it's only .3 miles it's less work than switching wheels multiple times. If it still has air tomorrow go ahead and drive it to a tire shop.
Users browsing this forum: No registered users and 107 guests
