Looks like we will be selling one of our two Miata's as we are hoping to move. Put in an offer on a place today. I have some minor things to take care of on this car, but it should be ready to sell soon. I know it isn't 4x4, but figured I would give a heads up to anyone on the board who might be interested before it goes to the general public.
Details:
1992 Miata with 130,000 miles. We are 3rd owners.
Has EVERY option offered in 1992 including the original removable hardtop with defrost. Convertible top in good shape too.
Also has an aftermarket turbo system that was installed around 30,000 miles. Complete including inter-cooler, boost gauge, and ECU setup. Includes original install manual.
Also has Borla exhaust with original paperwork installed around 30,000 miles.
1992 Miata with Hardtop and TURBO!
I got this car as a project with a hole through the side of the block. I installed another 1992 engine with approx same miles. Did LOTS of maintenance work to the engine before it was installed:
New clutch set (disc, pressure plate, throwout bearing, pilot bearing, etc)
New clutch master cylinder
New clutch slave cylinder
New Goodyear timing belt
New rear main crank seal
New oil pan gasket
New valve cover gasket
New spark plugs
New fan belts
New water pump with seals
New coolant bypass hose and o-ring
New cam seals
Oil change
Antifreeze change
Nearly brand new convertible top with zipper glass window
Nearly new rear tires. Front tires are worn but I have a used pair to go with car.
Front and rear brake pads have 80% or more pad remaining.
Features that car came with from factory:
Fiberglass hardtop with defrost grid and headliner
5-speed manual transmission
Power steering
A/C
4 wheel disc brakes
Power windows
Power antenna
Cruise control
Speakers in seat headrests and doors
Flip up headlights
14" aluminum wheels
As the car sits, including the hardtop I am looking at around $5,500. If you don't want the matching hardtop, price for car is $4,500 as the hard top would easily sell for $1,000 used.
Also, I have several other performance aftermarket accessories that are not included, but can be worked into a deal. These would include 15" Mazda Protege aluminum wheels, later model frame and body bracing for less body roll (started in 1994), larger brakes (started in 1994) with vented rotors, aftermarket shocks/coils for better ride and lower stance. Also have accessories that can be included into a deal such as a boot cover for when the convertible top is folded back or a tonneau cover that covers the entire cockpit when the top is folded back.
New oil pan gasket
New spark plugs
New fan belts
New cam seals
Oil change
Antifreeze change
Power steering
A/C
4 wheel disc brakes
Power windows
Power antenna
Cruise control
Flip up headlights
14" aluminum wheels
New oil pan gasket
New spark plugs
New fan belts
New cam seals
Oil change
Antifreeze change
Power steering
A/C
4 wheel disc brakes
Power windows
Power antenna
Cruise control
Flip up headlights
14" aluminum wheels
New oil pan gasket
New spark plugs
New fan belts
New cam seals
Oil change
Antifreeze change
Power steering
A/C
4 wheel disc brakes
Power windows
Power antenna
Cruise control
Flip up headlights
14" aluminum wheels
- roninsoldier83
