Sent from my iPhone.
ecam8000 wrote:OBDII does do an auto reset on most codes after certain conditions (like 12 heat cycles - cold start to warm - and no additional problem with that sensor). You are prbably fine, but that code can come back. Your t-stat may not be a problem at all. Personally I would drive it and if the code comes back again, then deal with it.
Users browsing this forum: No registered users and 109 guests
