FS: Infinity sub and Rockfor Fosgate amp
Eclipse
Postby Eclipse » Tue Feb 15, 2011 9:14
This setup was in my newly acquired purchase, and Im not interested in keeping them.. all is in working order.
Rockford Fosgate Punch 200
Infinity 12" sub with box. I have not removed the sub from the box, so I do not know which model the sub is, but I can do it if needed.
$300 OBO...make me an offer, these need out of my garage
Powerstroke 6.0
Postby erod550 » Tue Feb 15, 2011 9:14
99% sure that's an Infinity Kappa Perfect. I have one sitting in my garage and it looks identical to that sub.
Eclipse
well, that mustang of yours could use 2 of them ;)
Powerstroke 6.0
Hehe, like I need more weight in this boat. Plus they are single voice coil. :(
reconbygod12
Postby reconbygod12 » Tue Feb 15, 2011 9:14
i am interested but i honestly dont know how to tap teh bose system
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Eclipse
reconbygod12 wrote:i am interested but i honestly dont know how to tap teh bose system
do you have a stock bose sub? If so, it is quite easy to tap the low level input off the sub.. I found a thread on 6club and did it to my speed as well. You can even tap into the remote amp turn on also off of the same harness
Powerstroke 6.0
Fly boy
Postby Fly boy » Tue Feb 15, 2011 9:14
http://www.mazda3forums.com/index.php?topic=146671.0
Eclipse
Unless your setup is totally different, it is WAAAY easier to tap into the low level (preamp), instead of using the LOC because you are going into low level (RCA) outputs anyways into the amp. You need the sub to be low frequencies only, the bose preamp signal works fine..
Powerstroke 6.0
Fly boy
Postby Fly boy » Wed Feb 16, 2011 9:14
OCD wrote:Unless your setup is totally different, it is WAAAY easier to tap into the low level (preamp), instead of using the LOC because you are going into low level (RCA) outputs anyways into the amp. You need the sub to be low frequencies only, the bose preamp signal works fine..
but then you lose the bose correct?
Got of picture of where you tap into them? I am curious now. Installing the LOC was cake. didn't even have to take the seat out.
Eclipse
Postby Eclipse » Wed Feb 16, 2011 9:14
Fly boy wrote:but then you lose the bose correct?
All you are taking from the Bose sysytem is the preamp signal that the bose amp uses to amplify the sub. Nothing is lost except for the stock sub, but I'm sure you could even keep that hooked up with the aftermarket subs if you wanted.
Powerstroke 6.0
rmeeker13
Postby rmeeker13 » Thu Mar 03, 2011 9:14
I tapped into the front speakers pre factory amp under passenger seat, was the first thing I ever did to my car. Still works perfectly today!
BUMP
