Hopped on the dyno today
Postby erod550 » Thu Jan 13, 2011 9:14
Just wanted to see how much of a difference 2psi (16 to 18) and the car not being heatsoaked from an hour and a half of tuning would make. Turns out not much lol. 250whp/277wtq uncorrected. I guess that's not bad for the stock turbo considering there are quite a few guys at sea level running 290whp with similar mods. Urgh, I need a GT3071 lol. Made some cool smoke though :D
[ame="http://www.youtube.com/watch?v=KieTgMaTSCs"]YouTube - Mazdaspeed 3 Dyno Run[/ame]
[ame="http://www.youtube.com/watch?v=05YWuDECXV4"]YouTube - Mazdaspeed 3 Dyno Run[/ame]
Postby chickenwafer » Thu Jan 13, 2011 9:14
Not bad uncorrected...but I would imagine you're maxing the stock turbo
Postby RX-7 Chris » Thu Jan 13, 2011 9:14
and cool fire.
where did you take it?
Postby movovr » Thu Jan 13, 2011 9:14
That's a hell of a lot of smoke there bud....are you catless? I had the same mods you do with a catless DP and never saw smoke like that from my car.
Took it to MAC.
Yes, I am catless. I don't normally see smoke like that except if it bangs off the rev limiter, which he did on that run. I puffed smoke like that at the track too when I hit the rev limiter once. Normally I shift well before then, especially looking at my power curve, which peaks at 5500rpm and then starts to drop off. Not as steeply as stock, but still I'm making way less power at 6500 than 5500.
Yes, I'm pretty sure my poor little K04 is maxed. It is getting harder to resist upgrading the turbo instead of paying off bills lol.
pay the car off, than it is yours and you can do whatever you want to it.
mOOsE
Postby mOOsE » Thu Jan 13, 2011 9:14
wow, lot of unburnt fuel at the end there. Crazy
Postby iani1.1 » Thu Jan 13, 2011 9:14
haha i know who's red s13 that is
With the bosozoku tailpipes and stretched tires? I took a pic of it just for you, lol.
They also had a Neon SRT-4 that they just put a big FMIC and ATP GT3076 onto. Nick was going to tune it after I left, expecting around 400whp. They were also finishing up a 600whp Supra and Nick was telling me about an NA Miata that he just tuned that had a swap from an S2000. Made about 495whp at 9k rpms. Super linear power curve, like a straight, diagonal line.
dsm_luck
Postby dsm_luck » Fri Jan 14, 2011 9:14
Do you have an 1/4 mile times with that setup? That seems like good numbers. Your mods are similar to mine. I haven't gone with an upgraded fuel pump yet because I have never seen my pressure drop below 1600 at WOT. Did you change it out just in case or were you seeing a drop in pressure?
Postby erod550 » Thu Feb 10, 2011 9:14
Sorry for the late reply..
I suck at launching so my best time was 14.4 @ 101 with a 2.4 60'. My BATs were into the 180s on that run as well so I was losing a lot of power there. I'm sure with a better driver and/or slicks/drag radials it would have run 13s easily.
I went with the HPFP just in case. Never saw pressures below 1600 at WOT.
Postby Huzer » Thu Feb 10, 2011 9:14
Ah, man. I saw this thread and thought maybe you had tossed the Mustang on there already for a baseline!
Hehe, not yet. It's been stuck in the garage because of the snow. I will get a baseline soon. It won't be anything spectacular though thanks to the altitude. I'm guessing stock will be under 300whp, like 285whp or something crappy.
Postby RX-7 Chris » Thu Feb 10, 2011 9:14
you really think that low?
Stock at sea level people are dynoing anywhere from 360whp-390whp. Figuring approximately 3% loss for every 1,000ft of altitude (18.6% for 6200ft), that's anywhere from 67hp to 73hp loss. So that would put it in the range of 293whp-317whp. So I guess maybe not as low as 285. But it could still very well be under 300. Especially because the Dyno Dynamics dyno I plan on using reads low. A 1.15 correction factor on that dyno usually gets you to a similar reading as an uncorrected Dynojet.
The important thing is gains after mods anyway, and I'll be dynoing again after I get a few bolt-ons on there.
Users browsing this forum: No registered users and 107 guests
