Anyone else with this problem?
Originalguy
Postby Originalguy » Fri Jan 07, 2011 9:14
After disconnecting the battery for any reason ive always noticed a need to reset stations on the radio which is quite understandable, but does anyone else lose control of their passenger and rear windows? for about like 2 weeks after any kind of battery disconnection ill always be unable to open or close the windows from my driver controls, and even the automatic feature on my driver window doesnt work i have to hold it down the whole time...anyone else get this?
Mazdaspeed FTW
Postby erod550 » Fri Jan 07, 2011 9:14
I believe Stealth mentioned this before and knows how to fix it.
bobopud
Postby bobopud » Fri Jan 07, 2011 9:14
After a battery disconnect you have to reprogram the auto up/down and driver side control for all windows.
To do it go to each window control and roll the window all the way down and then all the way back up. When the window reaches the up position continue holding the control up for 2 additional seconds or until you hear a click. This will allow the auto up/down feature for the window and allow for the driver to control all windows.
Postby ~Barn~ » Fri Jan 07, 2011 9:14
It's also explained in the owners manual.
Image 720.935.6438
Originalguy
Postby Originalguy » Sat Jan 08, 2011 9:14
sick thanks guys
Mazdaspeed FTW
Users browsing this forum: No registered users and 200 guests
