My own thread...now with more issues!
Postby speedjunkie » Sat Dec 11, 2010 9:14
I'm glad you got the car back to what it's supposed to be. It almost sounds like you had a vacuum leak or something. Several years ago I got a HUGE leak when the coupler between the y-pipe and top IC pipe split about half way through.
I was about to ask if you if you forgot haha. When Brian was here he looked at the map but couldn't really tell about much wrong because he uses Motec. Someone else is telling me it just needs about 30% fuel added. Since you've worked a little with the PFC hopefully you can help. I'm going to check to make sure the wiring is applying power to the injectors too. And I also want to check them with a 9v battery like I did with all the others, do you think that would be a problem?
Postby chickenwafer » Sat Dec 11, 2010 9:14
Ya, double check all connections on the injectors, and you can try pulsing them with power or ground with a 12v car battery to make sure they aren't stuck.
The engine fires up and does run, right? When it stalls out, does it smell like gas? Perhaps try pulling the plugs and see if they're fouled. If the motor is flooding then it could be a bad injector. If they're dry then you're not getting enough fuel.
Stupid question, but you did remove the resistors/FJO box right?
Oh I was just talking about checking my splicing job, that's all. I have noid lights to use on that. And I used to use a 9v directly on the injector to hear it click and make sure it's working. It fires up and runs but won't stay running unless I blip the throttle constantly. It doesn't smell like gas when it dies, no. I don't think anything is leaking and I truly believe all injectors and plugs are firing because it sounds normal when it's running, so I really think it's just something in the map, but if I keep having trouble even if I add more fuel I'm going to check everything. I really do think it's something in my settings though, I just wish someone could tell me what it was haha.
So did you remove the FJO driver box?
Oh yeah, sorry, yes I did remove it haha.
Well I went through your map quickly, Eric, I changed a few things with the fueling setup that looked pretty wrong. I also adjusted your radiator fan temp switch on point because it was pretty high (hope that's okay)
I also glanced at other tabs in your map and some of them seem way off, especially ignition timing. The leading coil isn't too bad but the trailing/split timing is pretty aggressive, it almost looks an E85 map, I would be cautious with it. I can make you a much safer ignition map if you like.
Anyways, try this map out and let me know how it works. I'm free all day tomorrow, just sitting at home watching football, so feel free to call or text to troubleshoot.
http://www.mediafire.com/?46w4b55vw9o79nd
Cool, thanks! I'll give it a shot real quick. Yeah I don't mind that you changed that stuff, and if you want to mess with the timing that's fine too.
Just a note on "settings 5" real quick though...the injector section is one thing they told me to change...primaries to 79.7 and secondaries to 0, and to change pri/sec transition % to 35 or so and the sec transition ms to 0. But I'm gonna try this real quick anyway.
Who told you to change the transition to 0ms? That makes no sense, your secondaries won't be firing in time then. I don't think you're getting enough fuel and that's why it stumbles and dies.
WOOHOO! It stayed running! Although it sounds really weird now. It's hard to explain, but there are a few different noises now. One sounds like the turbine wheel scraping the housing, which I've heard before but not this bad before. I did have the houseing off to get an elbow welded on, I'm going to check on that. Another sounds like the injectors are really loud or something and clicking very distinctly, I'll have to ask others about this.
Postby chickenwafer » Sun Dec 12, 2010 9:14
Glad it stayed running for ya man.
Like I said on the phone last night, try playing with the battery voltage vs injector dead time. It's unlikely but perhaps the injectors are just louder than normal injectors?
Postby speedjunkie » Sun Dec 12, 2010 9:14
Are you talking about the lag vs bat voltage? My fuel pressure was around 40psi so I adjusted it up to around 43.5psi. I'm going to cut the sec transition in half too like you said and see what happens. I'm also going to check with others and see if the injectors are just loud haha. Thanks again for your help.
Yeah, the offset table you adjusted earlier. Maybe try taking a video clip of the noise so I can hear it, it will give me a better clue as to what's going on.
Can you hear it if you just turn the key to the ON position without the engine running?
We also need to talk about a tune, or at least letting me clean up your ignition timing
I think the car has to be running to hear the noise. I'll try it just with the key turned though. I'll record it on my phone and try to send it to you. And I'll bring the car up to have you tune it next time haha.
Sent you an email with the link to the video.
Got the video.
Honestly, it's hard to hear much, but it honestly sounds like an exhaust leak or something. I can hear an odd noise from your turbo, which sounds like the compressor every so slightly contacting the compressor cover, or it could be bearing noise. Hard to tell. You said you got an elbow welded on the compressor cover, so it's possible the cover got slightly warped from the heat if the welder didn't do it right.
If you can't hear any noise from the injectors with the key in the ON position, then it's 99% not a noise from the injector.
Users browsing this forum: Google [Bot] and 76 guests
