Mazda 3 tune?
42boxer
Mazda 3 tune?
Postby 42boxer » Thu Oct 28, 2010 9:14
I know this might be a really stupid question but ill ask anywas haha.
I know colorado alltitude hurts cars perforance wise. I have a SRI and will shorty have a MS3 exhaust on my 2.0 3. My question is i've heard of getting your car tuned so is this possible for my car and would it make a difference at this alltitude and with these mods? Thanks
Postby iani1.1 » Thu Oct 28, 2010 9:14
any tune makes a car run better or faster. an apexi safc will be fine since your not turboed or any of the sort. just installed and tuned mine a couple days ago and i feel a slight difference in power as well as better fuel mileage. this is all on a completely stock setup on my 2.3
Postby bellalyssa » Fri Oct 29, 2010 9:14
I thought you couldn't tune a 3???
I have been misinformed. I must look into this.
reconbygod12
Postby reconbygod12 » Fri Oct 29, 2010 9:14
any car can be tuned as long as you either have the software for it otherwise if your ecu can be tapped openly, but if oyu have a mazda 3 i would wait until you have all parts you wnat for the engine or exhaust
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby RX-7 Chris » Fri Oct 29, 2010 9:14
You could get a tune and it would help a little. Don't expect much in the way of HP gains. You may be able to help the power band though.
To get any power out of an N/A car you need to work on the intake mani, head, and cam. I don't know if anyone makes larger cams or if anyone has done porting work.
Postby tbot » Fri Oct 29, 2010 9:14
I would say don't waste your money.
That's what I was thinking. Hopefully I can buy this intake and exhaust soon... Until then... screw a tune.
Postby iani1.1 » Fri Oct 29, 2010 9:14
well technically you cant really tune a 3. an safc only fine tunes a/f ratio and does maf/map compensations while tricking the ecu to read want it wants to. it was pretty much free from a friend so no money wasted lol. but ive been driving the car all week and used up only a 1/4 of gas as before id be about at half.
edit: this is with stock everything fyi
^^ I need that kind of fuel efficiency.
J'sMZ3
Postby J'sMZ3 » Sat Nov 06, 2010 9:14
DPtune offers a ECU flash for the 3... You need to get dyno'd with A/F and some data logging then overnight ship your ECU with the reports to them ... they flash and return, $550.00 plus shipping one time no charge for reflash. You will be without your car for about 2 days. Option two is get a group of people together (usually 5 or more) and they will fly out and do a group tune on the dyno possibly get a group discount. I brought this up awhile back but no one showed interest. They have a tune for the Mazda3, Mazda6, MX5 /Miata, CX-7, Protege, and RX-8. Then Hypertech has there Max Energy Sport unit for the 2.3L Mazda3, and Speed3 about $400-500 depending on where you buy it, also There is MazdaEdit from epifansoft for certain models. It requires a laptop, Tactrix Openport 2.0 cable, and knowing what your doing! I dont know the price on the MazdaEdit software...
http://www.dptune.com/index.html
Dynotronics Performance Tuning
Atlanta and Texas Offices
678.488.1011 office
678.897.4692 fax
dyno@dptune.com
http://www.hypertech.com/products-max-energy-sport.aspx
http://www.epifansoft.com/phpBB3/mazdaedit-discussion-f17.html
[font="Arial"]CorkSport Power Series Exhaust // CorkSport SRI // 17x7.5 RPF1's // TWM Big TypeR Shift Knob // TWM Full Replacement Short Shifter // SRPracing pedals // Redline Goods Leather // Custom Made Stainless E-Brake Handle // TB Groun // Timing Advance // GT LED Tail Lights // Neffy Wrap Door Inserts // Redline Tuning Hood QuickLIFT // MS3 front brakes // MZ5 rear brakes // MSDS Header// Yellow Speed Coilovers // coming soon... DPtune ECU Flash[/font]
mOOsE
Postby mOOsE » Mon Nov 08, 2010 9:14
I wouldn't bother. The gains won't be noticeable and the cost to tune and get a flash far exceeds what other mods would cost to put on your car. I came from tuning several N/A Honda's and trust me, it's not worth paying to tune with those mods. It's generally only worth it on N/A vehicles with heavy mods like cams, pistons/shaved head, porting, intake manifolds, header(s), etc. Even basic bolt-on's for most cars at this altitude will not exceed the fuel limitations and adjustments that the factory ECU can make. Tuning will certainly make things a bit more efficient, but in terms of more power, you might see a couple peak hp over your current setup is all.
Users browsing this forum: Google [Bot] and 119 guests
