Is the "divorced" downpipe design from Corksport really a better design? Also, Protegegarage has a good deal on two Corsksport downpipes and a manifold. Will the manifold produce any extra power if I don't put a full CB exhaust (ie, limit my mods to just the manifold, downpipe, testpipe and a pro-tune)?
Or should I just get the CPE or ATP downpipe?
I don't want to make my car loud.
Thanks
Which Downpipe for MS6?
94R2CSprings
- Member
DON'T GET DIVORCED!!! There were a lot of issues with those DPs and they're the biggest pita to install ever! I would recommend a CP-e DP. meeker is selling one for dirt cheap that I might pick up, just needs some work getting an ext wg dump closed (which shouldn't be too hard at all)
94R2CSprings
- Member
Cp-e has excelent build quality vs the ATP, but then again there's always flukes to that.
As far as divorced, I believe iirc there were boost issues, i.e. bad boost creep. In any case, I would go hit up meeker about the CP-e one that he has, KILLER deal. Even tho I have an un catted DP, I'm tempted to buy that one from him as well lol.
tbot wrote:DON'T GET DIVORCED!!!
I beg to differ! Wait...Oh, you're talking about downpipes. Nvm.
tbot wrote:There were a lot of issues with those DPs and they're the biggest pita to install ever! I would recommend a CP-e DP. meeker is selling one for dirt cheap that I might pick up, just needs some work getting an ext wg dump closed (which shouldn't be too hard at all)
Did you get any turbo-smoke issues with the catless DP? That's my main concern, even though that's SOOO far down the line for me it's not even funny. As I plan this out, I was planning on catted to keep the turbo from smoking...
tbot wrote:Cp-e has excelent build quality vs the ATP, but then again there's always flukes to that.
Yeah, I don't see too many positive comments about ATP on other forums...any of their products, really.
I did see someone on msf.org say they got a DP on ebay for like $279 that worked well, fit perfectly, and so on. Probably a roll of the dice, though.
tbot wrote:Even tho I have an un catted DP, I'm tempted to buy that one from him as well lol.
Because TWO down pipes are better than ONE! (If you sell the catless, and I have money, I might be interested...but I'd have to sell my left nut...which would get me about half the money...)
Seriously, you can't go wrong with CP-E. They over-engineer EVERYTHING.
I know the University of Wyoming was buying left nuts specifically a few years ago. Maybe check into that. They paid $30,000 AND gave you a free prosthetic
My cp-e is spoken for at the moment, ill keep yall updated!
As for my input on DP's... If ur running a stock turbo go catted unless yo want a constant cel and some cool smoke effects! CP-E is the way to go hands down or there's a company on MSF called extreme boost that has a nice DP as well. I dont have any personal experiance with the corksport dp but have heard a lot of bad things over the years.
94R2CSprings
- Member
Turbo inlets may not add anything substantial to bottomline HP numbers, but it's definitely a worthwhile addition, IMO. The way that the stock turbo reacts in terms of spool-response, is quite impressive. I noticed it immediately after the fellas installed it for me, and because of it, your bottom end HP immediately becomes more usable, and available so-to-speak.
I'm not going to say that it will eliminate turbo lag, but it will smooth out the sloppy-air enough, so that when you're sporty driving, the boost actually feels like it's immediately behind the throttle, instead of on a slight delay.
94R2CSprings
- Member
Users browsing this forum: No registered users and 154 guests
