Hey all,
Sorry for the long absent been working two jobs trying to make ends meet. I recently blew a head gasket on my car and don't have the money to rebuild the engine. I'm looking to sell the car for $600 O.B.O. I just replace the EGR Valve solenoid and bought a second hand egr boost sensor. Although the motor is shot the transmission is still in good condition (does leak a little). Rims are all original with P205/60-15 Bridgestone Potenza's. Front tires are about half worn with no abnormalities and rear tires are about 80% tread life. exhaust is stock and still in decent condition. Body has a dent on the drivers side from before i bought the car, however this has not affected the closing of the door. The passenger side door no longer has an outside door handle, hole was tac-welded closed with some body filler, not a perfectly smooth job but would be great if you wanted to do a shaved door kit. Trunk lock was busted when I bought the car so i removed the lock cylinder and filled in the hole. I had planned on removing all handles and insignia when I had the money to spare however that never happened. Has new front brake pads and rotors with a set of pads and rotors for the rear that are still in the package. Has a homemade shift boot that was not completely finished made out of a black checkered material. Lining was falling off the ceiling so I removed it, the padding is still there just the fabric is gone for the most part. I will be removing the stereo unless you want to pay a little extra for it $100 for the head unit and another $50 for the back speakers, all are off the shelf from wal-mart.
If you have any further questions please give me a call at (970) 467-0018
I have checked and you can get a low mileage motor ready to drop in for approx 900 with a 1 year warranty. I was going to do this but I drive 100,000 miles a year now and need to get something with a little better gas mileage.
Thank you,
Allen
For Sale: 1996 Mazda MX6
coloradomx6
Up by 2200 down by 1500.
1996 MX6
Spectre Shortram Intake..........
1996 MX6
