New Ms6 Exhaust
InlineTwin
Postby InlineTwin » Sat Dec 15, 2007 9:14
Here is a pic of the cat-back I fabbed for my MS6. I need to tweak the fit a little more, but it looks okay and sounds good. The tone is low and not loud. Cruising at 70 the exhaust is barely audible. Wide open throttle has a pleasing growl that is not raspy or 'tinny'. I'll put it on the dyno in the next few weeks to see what the gain is.
Postby TheNewBlack » Sat Dec 15, 2007 9:14
Looks nice!
Postby SpeedRacer » Sun Dec 16, 2007 9:14
very cool!
RX-7drifter
Postby RX-7drifter » Sun Dec 16, 2007 9:14
sweet man what kind is it
Postby Colombia28 » Sun Dec 16, 2007 9:14
So so Nice! Get a sound clip up if you can.
InlineTwin
Postby InlineTwin » Sun Dec 16, 2007 9:14
<div class='quotetop'>QUOTE (RX-7drifter @ Dec 16 2007, 12:38 AM) [url=index.php?act=findpost&pid=14370]<{POST_SNAPBACK}>[/url]</div>
sweet man what kind is it[/b]
I fabbed it. I used Magnaflow universal "wide open" mufflers and mandrel bent pipes.
MS3_Mafia
Postby MS3_Mafia » Tue Dec 18, 2007 9:14
Looks really good, nice job! Look forward also to a sound clip.
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
Rich
Postby Rich » Tue Dec 18, 2007 9:14
What size tips are those? And could you have gone bigger?
InlineTwin
Postby InlineTwin » Fri Dec 21, 2007 9:14
<div class='quotetop'>QUOTE (Rich @ Dec 18 2007, 02:35 PM) [url=index.php?act=findpost&pid=14638]<{POST_SNAPBACK}>[/url]</div>
What size tips are those? And could you have gone bigger?[/b]
They are oval 2.5" tips that are about 3.25" wide and 2.25" high. I could go bigger by removing the stock tip otherwise they would bang against each other. The challenge with the tips is the larger pipe going out the back the more the mufflers need to be angled down, which doesn't really look very good. Part of the bumper structure hangs down in that area and it is completely in the way.
For the sound clip I plan to use the dyno time as an opportunity to capture the exhaust note.
InlineTwin
Along the lines of the dyno does anyone know where to get 93? I used 93 for the baseline and I would like to get a relative comparison from the test.
Users browsing this forum: No registered users and 36 guests
