New Toy...
rush24
New Toy...
Postby rush24 » Thu Jun 03, 2010 9:14
So here it is.....my "new" ETS TMIC from rmeeker13....Thanks a ton.....So far it is an AWESOME mod.....It pulls like a MOFO....and feels great...the sound is the only thing that I have get used to...sounds more like a supercharger whine....but I love it..... The FMIC project is still in progress....I needed to order some more parts and they have been on back order for a bit.....soooo I figured that I needed something....:D
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
CheyMS3
Postby CheyMS3 » Thu Jun 03, 2010 9:14
NICE!! i totally want to do a TMIC upgrade, and you got that one for a great deal!!
if you ever sell it, hit me up!
rush24
CheyMS3 wrote:NICE!! i totally want to do a TMIC upgrade, and you got that one for a great deal!!
It was a great deal!!! and I'll let you know if I do sell it..ever....I plan on checking the numbers between the TMIC and FMIC when it is complete....see which one is better....
2007 Black CX7
SURE Motor Mount...
[/color]
Postby erod550 » Thu Jun 03, 2010 9:14
Do you have the shroud that goes around the outside that the hood ducting seals onto? Or does the CX7 not have all that? If it does and you're not using the shroud you're losing some effectiveness as that keeps all the air coming in through the hood ducting going over the TMIC and not dispersing throughout the engine bay.
rush24
erod550 wrote:Do you have the shroud that goes around the outside that the hood ducting seals onto? Or does the CX7 not have all that? If it does and you're not using the shroud you're losing some effectiveness as that keeps all the air coming in through the hood ducting going over the TMIC and not dispersing throughout the engine bay.
The shroud is not needed on the CX-7.....the cover that vents the air into the TMIC sits on the TMIC....unlike the Speeds....which attach on the hood....That's why some places sell the CX-7 TMIC as a different part #....it's just without the shroud...
2007 Black CX7
SURE Motor Mount...
[/color]
Ah ok. Haven't seen under the hood of the CX-7 so didn't know. Congrats on the purchase. It looks good.
rmeeker13
Postby rmeeker13 » Thu Jun 03, 2010 9:14
Looks good man, hope u like it! When u left earlier ur forge bpv sounded awesome...ur exhaust sounds really good to.
rush24
Thanks....I would rather have the venting like the Speeds so you can see the TMIC unlike the CX-7....See the difference....
2007 Black CX7
SURE Motor Mount...
[/color]
rush24
rmeeker13 wrote:Looks good man, hope u like it! When u left earlier ur forge bpv sounded awesome...ur exhaust sounds really good to.
Thanks man....I'm trying to decide if I want to put the Synapse on instead....
2007 Black CX7
SURE Motor Mount...
[/color]
Postby erod550 » Fri Jun 04, 2010 9:14
That shroud doesn't fit over aftermarket TMICs on Speeds. So once you ditch the crappy stock TMIC, you also ditch the nice looking cover.
rmeeker13
Postby rmeeker13 » Fri Jun 04, 2010 9:14
rush24 wrote:Thanks man....I'm trying to decide if I want to put the Synapse on instead....
I wouldn't man...that forge sounded really good...makes me wish id of put one on my car! Is it a V1 or 2?
rush24
Postby rush24 » Fri Jun 04, 2010 9:14
rmeeker13 wrote:I wouldn't man...that forge sounded really good...makes me wish id of put one on my car! Is it a V1 or 2?
It's the v1...the one that sounds like a mouse sneeze...it's just a thought on the synapse right now...still wanna sell it if I can..
2007 Black CX7
SURE Motor Mount...
[/color]
I intentionally stayed away from the Forge because of the swords clashing sound, but a lot of people like it. The Synapse you can barely even hear unless you're dumping 17+psi.
rush24
So I figured out what the whining sound was......one of the holes on the cold pipe side of the TMIC was stripped....this was causing the whining sound....air was leaking out.....I put a heavy duty screw through it and problem solved:D
2007 Black CX7
SURE Motor Mount...
[/color]
rush24
erod550 wrote:I intentionally stayed away from the Forge because of the swords clashing sound, but a lot of people like it. The Synapse you can barely even hear unless you're dumping 17+psi.
After adding the TIP the sound changed....didn't really like it...that's why I bought the Synapse....But after adding the TMIC it has more of a normal BOV sound.....not the ping sound anymore....I'm happy with it....for now:D
2007 Black CX7
SURE Motor Mount...
[/color]
