All Weather or Snow
Tire and Wheel Discussion
Ryanmmacoustic
All Weather or Snow
Postby Ryanmmacoustic » Wed May 19, 2010 9:14
Hopefully this question won't make me sound too dumb. But having never lived somewhere where it snows alot I felt it appropriate.
Living in Loveland can I get away with using all weather tires during the winter months or do I need to buckle down and pick up snow tires?
Right now I'm rolling on Hankook Ventus V12 Evo's (215/45/17). It's a great summer tire and here in Texas I can roll on summer tires year round, but I have a feeling that I'm going to at least need an all weather if not a snow tire.
Any info would be appreciated
Postby Huzer » Wed May 19, 2010 9:14
If you're planning on swapping tires with the seasons regardless of type, I'd say go with snows. Realistically, the only car I've "needed" snow tires on was the RX8. I made it through winter, although not very happily, in my Mazda6 on Kumho Ecsta SPTs. Other than a few larger storms during the year, we don't get a ton of snow.
Postby RX-7 Chris » Wed May 19, 2010 9:14
Depends on how you drive, lol.
Ryanmmacoustic
RX-7 Chris wrote:Depends on how you drive, lol.
I'm a "spirited" driver I guess. I don't haul *** everywhere I go. But I go fast when I need to lol
If you just plan on having one set of tires than go with all seasons. If you don't mind changing out the tires and having 2 sets than get a set of summers and a set of winters.
Postby TheNewBlack » Wed May 19, 2010 9:14
Snows !
roninspeed3
Postby roninspeed3 » Wed May 19, 2010 9:14
There have been a few "spirited" discussions on the matter so you might research some previous threads. I run the stock RE50's in summer (till I chew them up) but have had VERY good luck and performance with Yokohama "W" Drive snows. I'm not sure what to do either but All Seasons I think = compromise. When you really want to corner in the summer or when winter conditions are max (which happens here also) the right tire for the season will prevail. Like the members have said "depends how you drive". I would like another set of wheels eventually and have two sets to optimize performance.... that's just me....
2008.5 MS3 GT (Metro Grey)
Custom install-Parrot MKi9200
Garmin 1350T
Speed 3 CAI
TurboSmart BOV
VEI Vent Mount Boost Gauge
Yokohama W Drive - Winter
Mats and Cargo liner
Postby Ranger » Wed May 19, 2010 9:14
I second what's been said. In a front wheel drive car, you should be ok with some all seasons that are M+S rated. But I would say that if you can afford to keep two sets of wheels / tires, definitely keep your summer tires, and buy a cheap set of rims to put snow tires on.
deepSpeedMS3
Postby deepSpeedMS3 » Wed May 19, 2010 9:14
If your looking for a set let me know. I have a set of all-seasons on 18x8 RX-8 rims for sale. PM me for more info.
B) deepSpeed MS3 B)
Postby dommo_g » Wed May 19, 2010 9:14
Don't waste you're time with all-seasons. Tires that are OK for all four seasons aren't going to be great for any one season. AS tires will only hinder your summer driving, and won't be as good as snows if the weather gets real bad. The upfront cost of snows and wheels will be more than offset in the long run when you don't have to pay mount/dismount charges every winter/spring.
Justin
Postby Justin » Wed May 19, 2010 9:14
Snows. Tire selection is as much about temperature range as it is about tread. Snow tires have rubber compounds blended to grip better at temps under 40 and will actually do better on dry pavement than all season tires at low temps.
Postby erod550 » Wed May 19, 2010 9:14
Definitely a separate set of snows and keep summer tires for summer. You can even get performance winter tires that do pretty well on dry roads in the winter. I'm extremely happy with my Michelin Primacy Alpin PA3s. I had always gone with dedicated snow/ice tires like the Hankook Icebears and General Altimax Arctics before this past winter and loved how they performed in snow but hated how squishy and floaty they felt on dry roads. Plus my ABS would kick in much easier on hard stops on dry pavement. These Michelins have done great for a winter tire on dry roads and were also very good on snow.
Postby bellalyssa » Thu May 20, 2010 9:14
dommo_g wrote:AS tires will only hinder your summer driving
I disagree with this statement. I tear **** up with my AS. With that said, I've gone through winter with my Goodyear Eagle GTs. I plan on switching to a winter tire when I get the money, but with you, I'd suggest you keep your summers until winter comes around and then get a dedicated set. You'll definitely save money that way.
Postby erod550 » Thu May 20, 2010 9:14
If you tear shit up with all season tires, you'd tear even more shit up with summer tires. There's no getting around the fact that all season tires do not perform as well as summer tires on (warm) dry pavement. You are willing to compromise for the convenience/cost and that's fine, but dommo's statement is true.
Another thing to consider Lyssa is that you don't have traction issues in a regular 3. In an MS3 it becomes a struggle to get the power to the ground so having good tires becomes even more important. I could never run an all-season tire on a performance car. Just seems completely counterproductive to me.
Return to “Tires and Wheels”
