2007 Pwertrain Warranty
Postby AIM WO4 » Tue Feb 09, 2010 9:14
I have been considering some modifications, so I checked what is covered on my 2007 Mazda5... I still have 2 years left on this stuff? :confused:
POWERTRAIN LIMITED WARRANTY
Mazda warrants that the [url=javascript:popup3('displayPage.action?pageParameter=legalTermsPowertrain','powertrain',440,510,'no','yes','no','no')]Powertrain Components[/url] of new 2007, 2008 and 2009 Mazda cars and trucks will be free of defects with normal use and prescribed maintenance for 60 months or 60,000 miles, which ever comes first. Ordinary maintenance items or adjustments, parts subject to normal wear and replacement and certain other items are excluded. This “limited warranty” is transferable during the warranty period on all new Mazda vehicles sold and serviced in the United States.
Powertrain Warranty Parts List
The listed below are the powertrain components covered under the Powertrain Limited Warranty:
Engine
  • Cylinder Block, Cylinder Head, and All Internal Lubricated Parts (Piston engines)
  • Rotor Housing and All Internal Parts (Rotary engines)
  • Timing gears
  • Timing chain/belt and tensioner
  • Timing chain/belt front cover and gaskets
  • Flywheel
  • Valve Covers
  • Oil Pan
  • Oil Pump
  • Intake Manifold
  • Exhaust Manifold
  • Engine Mounts
  • Turbocharger Housing and All Internal Lubricated Parts
  • Supercharger Housing and All Internal Lubricated Parts
  • Powertrain Control Module
  • Water Pump and Gasket
  • Thermostat
  • Fuel Pump
  • Seals and Gaskets
  • Freeze Plugs were not added
Transmission and Transaxle
  • Transmission Case and All Internal Parts
  • Torque converter
  • Clutch Pressure Plate
  • Transmission Mounts
  • Transfer Case and All Internal Parts
  • Transmission/Transaxle Control Module
Front/Rear Drive System
  • Final Drive Housing & all Internally Lubricated Parts
  • Manual and Automatic Hub (4X4)
  • Front Wheel Hubs and Bearings (FWD Transaxles)
  • Rear Axle Housing & all Internally Lubricated Parts
  • Axle/Drive Shafts
  • Propeller shaft (RWD and AWD only)
  • Universal Joints
  • Constant Velocity Joints
  • Rear Axle/Hub Bearings (RWD and AWD only)
  • Seals and Gaskets
Postby dommo_g » Tue Feb 09, 2010 9:14
So what were you thinking of modding?
Wouldn't you like to know.... :D
I'd like to just eventually start anything to help performance. Guess I'll have to see what won't negate the warranty first. All I have is the SRI/CAI. Maybe some suspension and exhaust... :confused:
T-time
Postby T-time » Tue Feb 09, 2010 9:14
f2 turbo kit http://www.f2usa.com/products/F2-Turbo-Kit-Stage-2%2C-7-psi-Intercooled.html# its made for the mazda3 but it should work with hardly any modification... if you dont want to do any wiring try their s/c http://www.f2usa.com/products/06%252d09-Mazda3-Supercharger-Kit-2.3-Manual-Stage-1.html
