The 15 Minute Start Up
Postby Huzer21 » Thu Nov 29, 2007 9:14
Well, yesterday, I went to move the RX-8 outta the garage after sitting there unmoved for the past week. The car was angry with me for suggesting that and promptly refused to start. I cranked until all of a sudden, the dreaded smell of gas filled the garage. Ugh, I flooded the damn thing. Followed the procedure to get it started (floored it), and it took about 15 minutes to finally get the car to fire up and idle...amongst quite the huge plume of exhaust. I had to open every window in the place to get the smell out of the loft.
Postby tsx_guy » Thu Nov 29, 2007 9:14
maybe it doesn't like the cold, you need to get her a winter coat. :lol:
<div class='quotetop'>QUOTE (6i_guy @ Nov 29 2007, 11:33 AM) [url=index.php?act=findpost&pid=12486]<{POST_SNAPBACK}>[/url]</div>
maybe it doesn't like the cold, you need to get her a winter coat. :lol:[/b]
I figure the garage should be enough of a coat! Tempermental little beast about the cold (or the long wait between start ups). Who knows...
ZoomPrincess
Postby ZoomPrincess » Thu Nov 29, 2007 9:14
I know Pooh Bears RX didn't like the cold either, it was very stubborn when trying to start. Plus the long wait could have just added to it
I see now there's a TSB for the hard start problem. I should probably check into that, although I have to pick a new dealer to frequent.
ZoomPrincess
you know which dealer I'm going to suggest... lol
<div class='quotetop'>QUOTE (CeXy7 @ Nov 29 2007, 11:56 AM) [url=index.php?act=findpost&pid=12497]<{POST_SNAPBACK}>[/url]</div>
you know which dealer I'm going to suggest... lol[/b]
mmm tough call there, gateway? Mcdonald? Lakewood? :lol:
ZoomPrincess
None of the above..... :P
Postby RX-7 Chris » Thu Nov 29, 2007 9:14
At least you have FI, I have a good old carb. It flood a lot. And you can't forget the carb freezing up and stalling.
Postby MazdaTom » Thu Nov 29, 2007 9:14
I was at a driver's school when it was cold and there was an RX-8 in attendance. His car would backfire alot on off-throttle and would smoke most of the time he was driving.
Just thought I'd share..............
<div class='quotetop'>QUOTE (MazdaTom @ Nov 29 2007, 12:46 PM) [url=index.php?act=findpost&pid=12507]<{POST_SNAPBACK}>[/url]</div>
Just thought I'd share..............[/b]
driver's school? as in driver's ed, remedial course? or was for auto crossing?
Hehe, I have parts to pick up anyway! Maybe I'll schedule an appointment when I go in.
Curious if they had a test pipe in the car, or if it was stock. I won't be driving much this winter anyway...maybe I'll get a beater for the winter.
Postby AIM WO4 » Thu Nov 29, 2007 9:14
My Mazda5 started right up after a week in the garage.
Postby GR-8 » Thu Nov 29, 2007 9:14
It's true, rotary's don't take cold well.
My car had problem last winter starting. Batterey was no good. Got a new battery free every 3 months till they finally changed the altornator. It starts fine. My problem I'm having now is that since it got really cold last week, in the morning or evening when the car is cold at start up the idle is high like normal and after a fe seconds the car just dies. Burt said that everything was fine. I'm also having misfire since the mountain drive. I'd like to drive someone elses 8 also to see how the tranny is when shifting if possible.
The backfire is normal in 8's when you let off the throttle. It's only not heard that much on stock 8's because the muffler cancels it out. IDK if you heard my 8 ever but with any aftermarket performance exhaust the backfire gets amplified a lot. on the smoking part My 8 only smokes a lot on cold days for about 10 mine. When it gets warmed up it's like any other car. It's mostly from all the oil that the 8 is burning while lubing up the rotors I beleive.
