Ingalls Stiffy ETD
J'sMZ3
Ingalls Stiffy ETD
Postby J'sMZ3 » Thu Nov 12, 2009 9:14
I'm going to see if Ingalls Stiffy ETD will fit on my 2010 Mazda3. From what I've seen not much has changed between gen 1 and 2 MZ3's in respect to the layout of the Engine and suspension mount points.
I contacted them well over a week ago and still haven't received a response back... so being the impatient Guy I'm going for it anyway! :eek: Might see one up for sale in a while... or not :1a98aa81:
CorkSport motor mount inserts are my other option. They fill the open space in the transmission mount to limit movement. I've heard they are pretty harsh and transmit quite a bit of vibration, they are working on a lower durometer bushing...and are allot cheaper than the Stiffy but I can't stand the jerky/sloppy feel on acceleration from the squishy motor mounts anymore! So I'm taking my chances with Ingalls!
[font="Arial"]CorkSport Power Series Exhaust // CorkSport SRI // 17x7.5 RPF1's // TWM Big TypeR Shift Knob // TWM Full Replacement Short Shifter // SRPracing pedals // Redline Goods Leather // Custom Made Stainless E-Brake Handle // TB Groun // Timing Advance // GT LED Tail Lights // Neffy Wrap Door Inserts // Redline Tuning Hood QuickLIFT // MS3 front brakes // MZ5 rear brakes // MSDS Header// Yellow Speed Coilovers // coming soon... DPtune ECU Flash[/font]
J'sMZ3
Postby J'sMZ3 » Wed Nov 18, 2009 9:14
Update... the Ingalls Stiffy ETD does fit the new 2010 Mazda3's. I mocked it up loose and all the mounting points line up. Going to paint the brackets, and then wait for my Vacation to install it.
IngallsEng
Junior Member
Postby IngallsEng » Thu Sep 02, 2010 9:14
J'sMZ3, do you have pics of your install? What modifications did you make to the strut tower bracket? I would like to discuss your installation with you if you or anyone else has used our ETD on a 2010 MS3 or 3.
Adam Moyer
Ingalls Engineering
303-665-7800 extension 16
J'sMZ3
Postby J'sMZ3 » Sun Oct 03, 2010 9:14
IngallsEng wrote:J'sMZ3, do you have pics of your install? What modifications did you make to the strut tower bracket? I would like to discuss your installation with you if you or anyone else has used our ETD on a 2010 MS3 or 3.
Adam Moyer
Ingalls Engineering
Havent been on the site in awhile just PM'd you. I'll try to give a call on Monday
Users browsing this forum: No registered users and 118 guests
