It's about time. These things have snapped, creaked, and left more than a few owners stranded.
From Autoblog:
Mazda's RX-8 sportscar is under the watchful eye of NHTSA for a problem that could effect far fewer vehicles but the problem is equally serious. The safety administration has reportedly received 40 complaints of 2004-2008 models that have experienced clutch pedal bracket failure, and in 15 cases, the rotary-powered Mazda was moving and the drivers couldn't change gears normally as a result. Two of those drivers could have found themselves in a more dangerous situation, as the clutch pedal was reported to have become wedged under the brake pedal.
At this point, NHTSA is just beginning to investigate these issues, and if a recall results in either case, the government agency will assuredly issue notice.
NHTSA investigating RX8 Clutch Pedals
took long enough
About time! LOL
It's amazing how flimsy the stock unit is. I took mine out and welded up some of the seams, it's just crazy how weak it is.
Oh yeah, about the weak ass Aisin transmissions- it's the same trans used in the new MX-5 Miata, and PAR Engineering makes a high strength gearset with syncro or dog-style engagement, billet shift forks, race ceramic bearings, and custom gear ratios. Only problem is I think it's around $3,000!!
chickenwafer wrote:About time! LOL
That's a great find about the tranny. If you think about it though the 3k might be worth it. I was quoted something like $1300-$1400 from mazda just to fix second gear and syncro. A new 04-08 tranny would run $2,700 and the 09+ is $2,900. So a few hundred more I may be willing to spend for a gear set that is stronger. Then the money to have someone install it.
The 09+ transmissions are completely different and braces on a different side, which would require custom transmission mounts or a different Power Plant Frame, lots of money.
If you're going to go through all that trouble you might as well put in an FD 5-speed or hell for the price of the 09 trans you could get a bullet proof Tremec T-56!
You can pick up used 8 gearboxes for $600-$800 all day long. The problem is they are used, so their lifespan is questionable.
Here is the link to the PAR Engineering gearsets:
http://par-engineering.com/sections/products/products.aspx?typeId=gearsets&manId=mazda§ionId=7
Looks like it's actually $4640 AUD, which at the current exchange rate, is about $4131.46 USD. For what you're getting it's not bad but IMO the better option at that price point is a Tremec T-56 6-speed, it can handle unlimited clutch drops (if your clutch can!), over 1200-rwhp and well over 1,000 ft-lbs of torque...and it only costs $3,000.
I always thought it would be cool to install a T-56 in my FB.
