i have an 88 626. four banger turbo, and i just got it running a couple weeks ago but there a few issues and was hoping you guys could help some..
first off when the car is first started it runs ok and idles but when you start giving it gas and let go it wont idle and just die.
the other thing is it has a big lack of power.. ill take off and i can floor it doesnt really take off i eventually get up to speed and shift through gears but i just dunno anymore.. so what would but some common things?? the car did sit for a year but im running out of ideas..
turbo 626 trouble
turbo 626 trouble
<a href="http://www.mybannermaker.com" target="_blank"><img src="http://i.imgur.com/pSgCq.jpg" alt='Create your own banner at mybannermaker.com!' border=0 /></a>
-"NOS is like a hot chick with an STD, you wanna hit it but you're affraid of the consequences!!"
Is it in gear when you're trying to give it gas? If so your clutch may be bad. It may not be transferring power to the flywheel which keeps it at an idle. It makes sense too that you don't get power when you're driving. If the clutch is bad it won't transfer power well at all. I'd get that looked at too.
before you go diggin everywhere. pull the codes. there is a green connector by the driver side tower strut. you need to ground it, then turn the key to the on position. it will flash the engine codes at you
01 Ignition Pulse
02 Crankshaft Position Sensor (CPS)
03 Cylinder Identification Sensor A
04 Cylinder Identification Sensor B
05 Knock Sensor or Knock Control Unit
08 Vane Airflow Signal (VAFSIG)
09 Engine Coolant Temperature Sensor (ECT)
10 Vane Air Temperature Sensor (VAT)
12 Throttle Position Sensor (TP)
14 Barometric Pressure Sensor (BP)
15 EGO Sensor (EGO)
16 EGR Valve Position Sensor (EVP)
25 Pressure Regulator Control
26 Canister Purge Solenoid (CANP)
28 EGR Control Solenoid Valve (EGRC)
29 EGR Vent Solenoid Vavle (EGRV)
34 Idle Speed Control Solenoid Valve (ISC)
42 Turbocharger Boost Control Solenoid Valve (BOOST)
biggest running issues other than sensors, will be your charge pipes leaking, and probably needing a tune up of some sort. the soft pipes like to crumble, as well as the throttle body boot. if you have any more issues, feel free to pm me. i know the f2t inside and out
01 Ignition Pulse
15 EGO Sensor (EGO)
my dad had one of these they are a pain to work on.. i hope its something super simple
~David
2008 Mazdaspeed 3 True Red
PTE 5858
JMF intake manifold
Cpe exhaust manifold
2008 Mazdaspeed 3 Cosmic Blue
PTE 5858
JMF intake manifold
Thanks, that helps alot im gonna try that first thing tommorow. and thanks zlyricist you are a big help if i need anything else ill ask.
once again thanks..
once again thanks..
Users browsing this forum: No registered users and 7 guests
