From UniChip, The dyno graph was impressive.
Just an FYI if you looking for a piggyback for under $650
http://www.streetunit.com/MAZDASPEED_6_Unichip_p/1320031.htm
MS6 Plug'n'Play
Cesaros
its a piggyback, plug into your obd sensor, and it automatically tunes your car. you dont tune anything, comes with maps and you can switch maps basically at push button...kinda like how diesel trucks do it with their piggybacks that they can switch from "race" mode to "tow" mode and "economy" mode...this makes so you can on the go tune your car to run at higher boost rather than having to take it into a shop and have them tune your stand alone management system...its completely "Plug and Play"...literally plug it in, ground to your clutch bolt, and drive.
heres Streetunits explanation:
plug and play -jargon:
1. Hardware or software that, after being installed ("plugged in"), can immediately be used ("played with"), as opposed to hardware or software which requires complex installation and/or configuration.
Choose Your Map We offer multiple calibration options for your MAZDASPEED 6. We can program the map on your Unichip here before it leaves our facility. For future modifications to your vehicle, the Unichip can easily be remapped. You can send the Unichip unit back to us to be remapped or the vehicle can be taken to a local Unichip Tuner to load a map which we can email them.
Airflow past the MAZDASPEED 6 mass air flow sensor is crucial for a proper tune. The Intake systems are the primary modification for different calibrations on the MS6. Choose your map based upon the intake systems below.
* Stock Intake or Slightly Modified
* AEM Cold Air Intake
* CP-E Cold Air Intake
* Injen Cold Air Intake
* MAZDASPEED Cold Air Intake
Optional Unichip Certified Custom Tuning The Unichip offers the option to get local custom tuning performed on your MAZDASPEED 6. The Certified Custom Unichip Tuner can tune your MS6 with Windows-based tuning software to maximize the performance of your MS6 and modifications, creating the most power as possible. To minimize faulty tuning and engine failures, the Unichip is only tunable by certified tuners that are located across the country. The Unichip is not tunable by the end user unless they have been certified by Unichip North America.
- Originalguy
ive looked at this ems and i thought it was impressive but i asked around and not too many people run it. most people stick with the cobb accessport or the cp-e standback. the only downside to this is that it comes with two maps but no software so that you can tune it yourself and there is a small amount of shops that deal with unichip so you dont have nearly as much convenience. If you want an piggyback go with cp-e's standback but if you want something a little more advanced without going full standalone go with the ap
Mazdaspeed FTW
Users browsing this forum: No registered users and 106 guests
