Tell me your opinions
Syko701
Postby Syko701 » Thu Apr 23, 2009 9:14
I just made this up yesterday took about 30 min and cost about 30 dollars to do but it reflects my bass so it sounds like i have a smaller trunk thus more bass and clean as well. It also hold my Capacitor and Amp very well. Tell me what you think.
- Bacon
excuse the sawdust i need to vacuum
Postby tsx_guy » Thu Apr 23, 2009 9:14
what did you use to make this and attach to your trunk?
Syko701
3/4 inch MDF (medium density fiberboard) carpet and screws
I think having the separator run up to the top of the trunk would look a little cleaner.
Syko701
right i agree but i would loose total functionality for my trunk i can remove the division in like two seconds and it looks alot cleaner in person. i think im just gonna recarpet the entire trunk and box black like the division that should help
Postby tsx_guy » Fri Apr 24, 2009 9:14
i was just thinking it would be more mysterious if you couldn't see the sub box at all, but still allowing for the quick removal. I need the majority of my trunk so I can't install a large sub box...
Postby GR-8 » Fri Apr 24, 2009 9:14
I was gonna say mebe placing the Amp and capacitor on the other side..... IDK may look cleaner. Unless you want to show them
goldrocket
Postby goldrocket » Sat Apr 25, 2009 9:14
If you need more space, you could make a panel for the side of the trunk, outside the hinge on one side, that goes from the bottom to the top and install the amp and cap on it. That way it's always out of your way and you never have to remove it.
Al says
