Lost a key...
RedRoadster
Lost a key...
Postby RedRoadster » Thu Apr 16, 2009 9:14
So, Laura managed to lose her keys this week.
Light searching reveals that programming a new key is only possible if one is already in possession of two programmed keys, and the only solution is to have ECU reprogrammed.
Can someone verify this?
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Postby Colombia28 » Thu Apr 16, 2009 9:14
No idea on how these things work, but good luck.
jt2589
Postby jt2589 » Thu Apr 16, 2009 9:14
if you have 1 or none you need to have a dealer program the new key. if you have 2 or more you can cycle the keys and do it yourself. what year and model is it?
Postby AIM WO4 » Thu Apr 16, 2009 9:14
You usually need 1 key.
RedRoadster
'08 3 4-door GT
Flyin' Miata stuff:
Postby GR-8 » Thu Apr 16, 2009 9:14
If you only have one key you will need a dealer to hook it up to their big computer machine thingy. It's the only way.
If you have 2 you can DIY. I assume that you got 2 keys + a grey vallet key when you got the car?
Postby AIM WO4 » Fri Apr 17, 2009 9:14
You may be able to by a second key and find the DIY instructions somewhere. I know the Saab community buys a second key off the web, and do it cheaper than a dealer.
Try here: http://www.mazdas247.com/forum/showthread.php?t=123712960
And here: Get the fcc id off the back of the other one, then look on ebay for a blank with matching fcc id.
Call these guys: http://www.trademotion.com/partlocator/index.cfm?siteid=214264
Or the NEXT post... LOL
jt2589
Postby jt2589 » Fri Apr 17, 2009 9:14
Red95FMII wrote:'08 3 4-door GT
The key is $25.40 plus tax. We charge $75.00 to program if we have to plug in to the PCM with the WDS(Big machine Thingy).
RedRoadster
Postby RedRoadster » Fri Apr 17, 2009 9:14
I don't recall receiving a valet key, but It's been a while. Does the valet key work in the reprogramming rain dance?
Flyin' Miata stuff:
Postby GR-8 » Fri Apr 17, 2009 9:14
AIM WO4 wrote:You may be able to by a second key and find the DIY instructions somewhere. I know the Saab community buys a second key off the web, and do it cheaper than a dealer.
I don't think this will work. You need 2 keys that are aleady programmed. At least I think.
The FCC id's really don't have much to do with anything. My flip key I got and programmed went just fine and it's a whole different FCC #.
Red95FMII wrote:I don't recall receiving a valet key, but It's been a while. Does the valet key work in the reprogramming rain dance?
I don't see why it shouldn't work. I know of a few people that never got a valet key. I was given one though. Never used it but it only works for the ignition and door. Will not unlock the glovebox, trunk, or trunk access door between the seats.
Users browsing this forum: No registered users and 102 guests
