how hard is it to bleed brakes?
The How-To Forum
Postby tsx_guy » Fri Jan 23, 2009 9:14
I may have to in a car and wanted to know the difficulty or should
i have a professinal do it. In terms of skills, I am pretty good with a tire iron but that is about it. I do not change my own oil. :mellow:
Postby AIM WO4 » Fri Jan 23, 2009 9:14
Easy. Find out what the order is from the manual.
I have a bleeder if you need to borrow it.
Or you can come by my place for help...
it would not be a mazda, and I am not sure if I would have the manual...I will see if this pans out. Thanks for the offer!!
I have 2 attachments... It's from my Saab days.
Postby MazdaTom » Fri Jan 23, 2009 9:14
Usually you work from the furthest brake from the master cylinder forward. So typically you go right rear, left rear, right front, left front.
With 2 people it's easy. With a bleeder thing that pressurizes the master cylinder and one person, it's easy. With a bleeder thing that acts as a vacuum trying to suck the fluid out..... I've never liked those.
Postby tsx_guy » Sat Jan 24, 2009 9:14
good to know, still trying to determine is this will be necessary. thanks!
Postby AIM WO4 » Sat Jan 24, 2009 9:14
Usually. Not always with today's ABS systems.
MazdaTom wrote:Usually you work from the furthest brake from the master cylinder forward. So typically you go right rear, left rear, right front, left front.
Return to “DIY”
