For those that havn't read on RX8 club Esmeril racing has pushed their RX8 to 414WHP & 304WTQ with their kit @ 16psi. Like anything on RX8club their is contrevoursy on the graph and everything..... Especially since most of the people with power on there mark this kit as being made up of Ebay parts..... They are also making 366WHP & 265 WTQ @ 13psi. When I do eventually get this kit I think I will stick around the 8-9 psi range which I believe was around 300WHP mebe move to 10-11 psi when I want some fun.... that would be around 340WHP i beleive...... ( I can't find their other graphs so am not sure on those last numbers)
The graphs they have were done in MPH instead of RPM because of some problem...... but @ 4K RPM in fourth gear you are traveling at 55MPH so @ 110MPH you should be around 8k..... you can use that to figure out the RPM range yourself......
And all I have to say is look..... a kit for the 8 with a turbo that lets you make power past 7k RPM.... wow..... Greddy is a fail......
Esmirlil racing is also in the process of making Performance Apex seals.....
Rx8club Thread
Esmerilracing.com
414WHP Dyno Proven 8
They had an older thread up about this. I didn't search, but I'll bet they deleted it because MM had chimed in calling their kit crap. While I'd love a high horsepower 8, I don't think it's in my future. I do plan on keeping the car, but if I want something that has hp potential, I'll build a V8. I'm just hoping for 200 at the wheels from my car.
- *DarthRX8*
Yeah, I have been following that thread too. My 8 is my daily driver, so putting that kit on and running 15psi and 414 whp would probably kill my engine in a few thousand miles.
The farthest I will go/ hoping to achieve is over 200 and I should be able to get that with a midpipe and a new tune on my accessport. The only thing I am worried about is voiding my warranty and not passing emissions. Maybe someday I will stop being a wuss.
OMG I want this kit so bad. Esmeril uploaded a new video of the 8 running 414whp on the street. So Sweet. You guys have to watch the video. They are running the kit with their ignition upgrade and their New Apex seals they are developing. So far they've logged 15k miles on this setup.
It's just amazing how much power it's putting down. To think that in the begining everyone said that this car won't make anywhere close to 300whp boosted. It happened. Then they said that 300 was the max, then they went to 360 was the max to now over 400WHP DD with over 15,000 miles and going. At the end of the video it says 500 WHP comin soon!..... I wish I had the cash to spend on this kit instead of more important things.
TURN THE VOLUME ALL THE WAY UP WHEN THE MUSIC STOPS TO HEAR THE GOODNESS.
http://videos.streetfire.net/video/Esmeril-Racing-414WHP-RX8_210037.htm
6i_guy wrote:400+ hp dd running for 15k miles is pretty impressive. I am afraid to ask what this kit costs.
For the potential power you could make out of it not that much really. Costs more than the Greddy kit but comes with way more including the power. It's $5,600. Greddy kit runs from 3,500 - 4,500 now a days and puts down something like 260ish WHP if your lucky. Then if you want more power you have to spend, I think, 1-2k more for MazdaManiacs Greddy upgrade. even than your 316 WHP.
so what does it make stock out of box with no upgrades?
well then get the kit already, I'm tired of hearing you talk about it.
Greek8 wrote:Straight out of the bix is something like 300+ whp. at i think 11psi. but u can tune it to 340-360 if you have the ignition upgrade which is lke $400.
The greddy and MM upgrade costs $6200 to make 316whp. so this kit makes more power for less.
Actually, the GT3071R turbo can support over 400-rwhp on the Renesis. You just need to turn the boost up, just like the Esmeril kit.
And the smaller turbo will get you better boost/throttle response in lower rpm- the Esmeril kit at 16psi doesn't hit full boost until past 5500rpm.
The main problem I have with the Esmeril kit is the EBay turbo, wastegate, BOV and the fact you can't tune it with the AccessPORT. Customers have documented the turbo crapping out after just a few thousand miles. And the wastegate position is less than optimal, it hangs lower than the oil pan so first speed bump and buh-bye wastegate!
chickenwafer wrote:Actually, the GT3071R turbo can support over 400-rwhp on the Renesis. You just need to turn the boost up, just like the Esmeril kit.
Yes it can support 400-whp but I have not seen of an 8 other than Esmerils to reach that number. PTP has reported 390 on their vehicle I beleive and has a similar sized turbo. The lag isn't that much of a problem seeing as I can get off the line pretty quick and first gear is over with like that so the lag shouldn't be much.
I don't see the big deal of it reaching full boost @ 5500RPM. As long as it's boosting it'll go. At least it doesn't give out @ 7k but it keeps making power. I mean even if you keep throttle @ 10 PSI and never reach full boost (16PSI) the car will still go. You also have basically 4k RPM off full boost usage. And when racing how often will you be below 4k RPM anyway? IDK. Those are just thoughts that I have.
As far as the Turbo being "Ebay" well I still have no fact to that. it could very well be a unbranded quality turbo. Ever shop @ Harbor Freight for tools? Their stuff there is pretty much unbranded quality tools. My brother bought and air gun there years ago and it is exactly the same externally and internally as the namebrand (Forgot the brand) gun is and is still kicking. It's a risk i'm willing to take. Plus they will be offering a name brand turbo in the coming months so yeah.
Wastegate and AP compatability are the 2 things that bother me. I thougt that the wastegate location was the worst place to put it. they could have atleast routed it straight back or even slightly angled or in a whole other area. But they are swithching to a low profile WG so that should be alright clearance wise. Plus if your smart you wouldn't go over extrem bupms and youd go over them the right way not head on. Isn't it right next to the wheel anyway. It should never hit ther unless you are flying over the bumps.
Now only if you could tune it with the AP would that be a perfect kit.
I've personally seen a car with the GT3071R hit 400-rwhp
Lag is a problem with the kit. You floor it and the turbo doesn't even start to spool until 3500rpm or even higher depending on what gear you're in. I can just tap the throttle on the highway in 6th gear and be in boost right now. You won't get that with Esmeril.
On the track, you can fall below the boost threashold easily. Entering a turn, low-speed sweeper, traffic, all can contribute to dropping rpm.
The biggest thing is throttle response. The Esmeril kit KILLS your throttle response- you have none.
I know of 4 people with the Esmeril kit that the turbo has crapped out on, all under 2000 miles. I'm talking serious oil leakage and shaft play. Why do you think they are now offering a Precision turbo and TiAL w/g? Because they had junk in their first kit
Of course the new stuff costs more money.
No one PLANS on running stuff over with their car, but it happens. A big rock, tire, road debris, etc can hit your w/g, too. It's just a stupid location, LOL
The EMS situation is currently the kits biggest flaw. The only viable solution is the Int-X which blows or the GReddy EMU which is slightly better, but both are bad systems. If I got the kit I would go full standalone with a Haltech E8/E11v2. it would be a bitch tho.
This is just my take on the kit. I think it has some good design properities but the turbo kills your throttle response, boost threshold, and doens't lend well to being on the track. It's hard to explain the delay in boost response to someone that hasn't driven it, LOL, but just trust me.
Of course the new stuff costs more money. No one PLANS on running stuff over with their car, but it happens. A big rock, tire, road debris, etc can hit your w/g, too. It's just a stupid location, LOL
Are these all on stock ports?
Made fast courtesy of Chris Sanders at http://www.banzai-racing.com/:
My 517rwhp dyno run:
http://www.youtube.com/watch?v=qv-583ecIAU
Users browsing this forum: No registered users and 105 guests
