Exhaust shops in the springs
Postby RX-7 Chris » Wed Nov 19, 2008 9:14
Does anyone know of good exhaust shops in the springs?
It needs to be one that doesn't care that I'm missing my cats. Also I want thick walled pipe and mandral bends. I want to do 2.5" with a magnaflow.
Low Impedance
Postby Low Impedance » Wed Nov 19, 2008 9:14
or for cheaper, you can buy some pipe, J bends and if i get my chop saw out here soon, we can just make it.
WWW.RCCDIGIZINE.COM
I did that on my galaxie but I really want something nicer
goldrocket
Postby goldrocket » Wed Nov 19, 2008 9:14
Catfish engineering in Fountain if they are still in business. Otherwise I know a few people who have had work done by budget and beem very happy.
Al says
s0n1cm0nk3y
Postby s0n1cm0nk3y » Fri Nov 28, 2008 9:14
subbin on this, Im looking to get a setup for not to terribly expensive. and I dont want a huge exhaust fart can on the back.
Postby RX-7 Chris » Tue Feb 17, 2009 9:14
I'm bumping this because I now have the money to do it.
Postby RX-7 Chris » Fri Feb 20, 2009 9:14
I have an apointment with Catfish Engineering for next Friday. I tried Buds Muffler in the springs and they wouldn't do it without a cat. Carfish will do it however I want and for half the price for the same stuff.
If they didn't work out then I was going to go to Buds in Denver.
Postby speedjunkie » Fri Feb 20, 2009 9:14
I was going to say Zico and the guys do that stuff too. But if you already have an appt at the other place...Zico is in Hawaii again now anyway and he's the one that does the welding.
Bask
Postby Bask » Sun Sep 25, 2011 9:14
where is catfish engineering located at? i want to run straight as well.
[SIGPIC][/SIGPIC]" Only mazda worth drivin are RE powered :p "
Postby RX-7 Chris » Mon Sep 26, 2011 9:14
2698 Delta Dr, Colorado Springs, CO 80910
They did an ok job, not the best in the world but the only choice if you want catless.
Postby erod550 » Mon Sep 26, 2011 9:14
I've had good work done at Muffler Masters on Austin Bluffs/Barnes and on Fillmore/Stone, and they looked the other way that I had no cats. They weren't the ones removing the cats though, so that might be different if you're wanting them to actually take the cats off. Most places won't do it cause if they get caught they face some pretty huge fines.
