New Reply on my own reply...
- Colombia28
I just noticed that when i myself post a reply in a thread and then return to the board index it shows up as a new reply in that thread for myself. Anyone else have this problem?
2008 Cosmic Blue Speed3 - NEW
- Colombia28
Let me try to clarify. I'm no good at clarifying things like this so bear with me.
Ok so when i post a reply in a thread (just like this reply), and then return to the board index to see whats new, the thread that i just replied in shows up on the index as if there is a new reply i haven't read. So it makes it appear that someone else has replied but they haven't, it is just my reply. Does that make sense? If you not ill call Josh and see if i can verbally explain it.
[color=black][font=Verdana]If that doesn’t make sense, go to a section that has no new replies, reply to a post in that section and return to the board index. Look at that section and knowing you were the last person to reply in it you will see it highlighted red for a new reply. Yet its your reply you just made. The "old" boards didn't do that.
[/font][/color]
[/font][/color]
What are you using to check for new posts? The link on the navbar up top?
I have this mod on my board, it's better than the built in 'new post' function.
http://www.vbulletin.org/forum/showthread.php?t=168303
I still don't see the error. If I check either New Posts or Today's Posts, and I just replied to a post, it doesn't show as unread. It does put that thread to the top, but it shows as read. When I go to the main board index, the forum does show as a new reply, but I tested that out on a few other vBulletin boards, and it does exactly the same thing. I'm just lost as to where/when/what is happening.
Thanks for the hack info. I'll check it out.
I see the same thing as you Tim.
Return to “Colorado Automotive Enthusiasts News and Info”
Users browsing this forum: No registered users and 45 guests
