new parts
<div class='quotetop'>QUOTE (Greek8 @ Aug 1 2008, 11:01 PM) [url=index.php?act=findpost&pid=59063]<{POST_SNAPBACK}>[/url]</div>
my exhaust should be here tuesday. the ap is my favorite mod so far, the acceleration feels smoother. ya i finally got them sorted out, im hoping when i get the exhaust i dont have to go through it again.
Congradulations man. Hurry and get your exaust components. I want to here what it sounds like with the midpipe. How you liking the AP? Did you get your maps sorted out and find the right one? Give some input. How's it feel?[/b]
2005 RX-8
<div class='quotetop'>QUOTE (icon @ Aug 1 2008, 11:54 PM) [url=index.php?act=findpost&pid=59064]<{POST_SNAPBACK}>[/url]</div>
Nah I don't think that you'll have to go through it again. What map are you running? Keep track of your LTFT throughout the week cause you may have to switch maps depending on how it looks and also your AFR. I know I messed with mine for about 2 weeks and was still running way rich.
my exhaust should be here tuesday. the ap is my favorite mod so far, the acceleration feels smoother. ya i finally got them sorted out, im hoping when i get the exhaust i dont have to go through it again.[/b]
<div class='quotetop'>QUOTE (Greek8 @ Aug 2 2008, 12:29 AM) [url=index.php?act=findpost&pid=59065]<{POST_SNAPBACK}>[/url]</div>
my ltft is at 0. what should my afr be at?
Nah I don't think that you'll have to go through it again. What map are you running? Keep track of your LTFT throughout the week cause you may have to switch maps depending on how it looks and also your AFR. I know I messed with mine for about 2 weeks and was still running way rich.[/b]
2005 RX-8
<div class='quotetop'>QUOTE (Huzer21 @ Aug 2 2008, 08:45 AM) [url=index.php?act=findpost&pid=59075]<{POST_SNAPBACK}>[/url]</div>
special maps make things compicated. and thanks
You people and your special maps. I'm jealous. Congrats on the AP and your new exhaust![/b]
2005 RX-8
<div class='quotetop'>QUOTE (Huzer21 @ Aug 2 2008, 10:13 PM) [url=index.php?act=findpost&pid=59122]<{POST_SNAPBACK}>[/url]</div>
I think he does send the cobb maps off with his base maps. Don't remember though cause the 2005 maps were loaded in and I DL the 04 ones from the Cobb site. We will see when Icon comes on.
Icon you going to the Sonic meet Sunday. Havn't been around for a while.
Does MM include the Cobb maps as well? Just curious.[/b]
<div class='quotetop'>QUOTE (Huzer21 @ Aug 3 2008, 08:54 AM) [url=index.php?act=findpost&pid=59139]<{POST_SNAPBACK}>[/url]</div>
I don't think Cobb will either. Just cause every car and location is different and MM basically will make a tune just for you and not just a general tune. Mebe MM will make a stage 2 for cobb but I doubt that.
Oh...duh! You can download em, I completely spaced that out. Haha! I think with MM doing his maps, it doesn't really seem like Cobb is going to come out with any different stage maps.[/b]
Sweet. Stop by the Sonic on sunday. Below is the instructions MM shoulda sent out. So if at wide open throttel you AFR is above or below High
12s-13s you will need to change the map. When you let off the throttle AFR will jump up to the 20's. That's fine. Email MM and let him know if you are to lean or rich and he will send you a different set of maps to correct it and you have to do the same process as before. It takes a long time but it's what you have to do. I was running way rich when I had mine.
<div class='quotetop'>QUOTE </div>
Save all of the files onto your AccessPORT with the AP Manager.
When you "install" the AP, select "MM 2004 MT NA v1_0.ptm" as your starting map.
Start the car and while it warms up, select "live data" on the AP an scroll through the options until you get to "short term fuel trim".
Watch that value and, once the car is nearly warmed up, take it around the block.
If the STFT is a negative value (check only at IDLE), you will use one of the files that end in "b". If it is a positive value, you will use a file that ends in "a".
The last number before the letter in the file name corresponds to the amount of fuel trim you want to remove. Here is the breakdown:
MM 2004 MT NA v1_0.ptm - start file, no trim
MM 2004 MT NA v1_1a.ptm - adds 2%
MM 2004 MT NA v1_2a.ptm - adds 4%
MM 2004 MT NA v1_3a.ptm - adds 6%
MM 2004 MT NA v1_4a.ptm - adds 8%
MM 2004 MT NA v1_5a.ptm - adds 10%
MM 2004 MT NA v1_1b.ptm - subtracts 2%
MM 2004 MT NA v1_2b.ptm - subtracts 4%
MM 2004 MT NA v1_3b.ptm - subtracts 6%
MM 2004 MT NA v1_4b.ptm - subtracts 8%
MM 2004 MT NA v1_5b.ptm - subtracts 10%
If the fuel trim is off the scale in one direction or another, let me know and I'll make adjustments.
Once the idle trim is correct (a few % one way or another is totally no big deal - in fact, up to 12% is acceptable since the PCM can go up to 22% before it starts to struggle), drive around in various conditions less that high load and see if the fuel trims stay within +/-6% or so of the idle trim.
If so, you are good to go!
Watch your A/Fs at high load. If they start to swing too lean or too rich, let me know.
You should be seeing high 13's in some conditions, mid 13's in most conditions and high 12's in others.
Watch your A/Fs through the "equivalence ratio" display in live data.
If you have any bogging or sluggishness, let me know the range and the A/F at that point.
Expect to see updated files from time to time and let me know if you have any issues.[/b]
Users browsing this forum: No registered users and 144 guests
