Quick Tire Question
Tire and Wheel Discussion
Postby Stealth01 » Thu Jul 10, 2008 9:14
Will 245/45/18s fit on the stock rims for the MS6? I have a shot at a set of Blizzaks for $40 with 9/32 tread left....
Postby GR-8 » Thu Jul 10, 2008 9:14
I would say yes.
Looks like they might not. TireGuy on the 6club lists 245 40 R18, but not 45 R18. Must rub. :(
Intresting. That would mean the 8 has bigger wheel wells. They fit on 3's so I'd assume they fit the 6 to.
Maybe they will. Waiting on the TireGuy to e-mail me.
Gmoney
Postby Gmoney » Thu Jul 10, 2008 9:14
i ran 235/40/18 on my stock rims with no rubbing(just barely). Pretty sure 245/45 will be a problem, not with just rubbing but that is a wide tire to put on a 7in wide wheel. Just my 2 cents.......try this link it was helpful for me in sizing wheels for my car.
Tire/Wheel Sizer
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
Ooops my bad. 245/45. I read it as 225/45. That may be a prob. Don't ever listen to what I have to say.
4doord
Postby 4doord » Thu Jul 10, 2008 9:14
I have 235/40r18's on mine and they are real close. I don't think they will fit. :2cents3fo:
bobopud
Postby bobopud » Fri Jul 11, 2008 9:14
245's will not fit on an MS6 under stock conditions for two main reasons:
1.) The stock setup of the MS6 wheel wells, without an enourmous fender roll that would be pushing the limits of the sheet metal.
2.) A 7" wide wheel, the tire is just too damn big. A 245mm wide tire is equal to 9.65 inches, those tires would be too far stretched to take any kind of corner, let alone a colorado pothole.
Postby Stealth01 » Fri Jul 11, 2008 9:14
Kinda what I thought. Oh well. Thanks guys.
Return to “Tires and Wheels”
