My Full LED Conversion
Zuhalter
Postby Zuhalter » Tue Jul 08, 2008 9:14
So I finally got all of the parts in from V-LEDS, and finished my complete LED conversion. I changed out every light except for the HID Headlights and the Foglights. I took a few pictures of the lights in the day, they didn't turn out too great, but here they are. I am going to take some night shots tonight.
I also took a few pictures of the resistors and where I mounted them for the flashers.
The cabin LEDs are U.V and HID White. The External LEDs all match the original factory colors except for the front sidemarkers which are now HID White.
[attachment=589:Dome_Light.jpg] [attachment=590:UV_Maplights.jpg] [attachment=591:Visor_Light.jpg] [attachment=592:LeftFront_Lights.jpg] [attachment=593:LeftFront_Resistor.jpg][attachment=594:LeftRear_Lights.jpg] [attachment=595:Right_Co...sy_Light.jpg] [attachment=596:RightFront_Lights.jpg] [attachment=597:RightFro...Resistor.jpg]
StormsOtherSide
Postby StormsOtherSide » Tue Jul 08, 2008 9:14
Looking nice man! :koolaidman:
MazdaSpeed3 GT
15% Tint, Blue Lamin'x Fogs, Vinyl EyeLids,
Cobb Short Ram Intake, HKS SSQV Black Edition BOV, Custom Deep Purple Flamed Intercooler, Corksport MM Inserts.
To Come: Wheels, Springs, COBB Short Throw Shifter, Tuner! :723b3bdf:
Favorite Quote: It's Not Real.
Postby Stealth01 » Tue Jul 08, 2008 9:14
Looks great, but did you put LEDs in the headlight housing? I don't think they'll last in there. I have red LEDs in my dome lights and love it, but will probably get the autolumination hyper white 194s for the DRLs.
Postby GR-8 » Tue Jul 08, 2008 9:14
Nice man. Congrats.
RX-7drifter
Postby RX-7drifter » Tue Jul 08, 2008 9:14
looks good
Postby Huzer21 » Wed Jul 09, 2008 9:14
Looks good. How's the auto dim look on the interior lights? Do they flicker, or does they still fade out like the stock bulbs?
Renesis Rx
Postby Renesis Rx » Wed Jul 09, 2008 9:14
Looks nice. Like the map lights.
Renesis...MMMMMMMMM
Zuhalter
Postby Zuhalter » Wed Jul 09, 2008 9:14
<div class='quotetop'>QUOTE (Stealth01 @ Jul 8 2008, 09:33 PM) [url=index.php?act=findpost&pid=55559]<{POST_SNAPBACK}>[/url]</div>
Looks great, but did you put LEDs in the headlight housing? I don't think they'll last in there. I have red LEDs in my dome lights and love it, but will probably get the autolumination hyper white 194s for the DRLs.[/b]
I did put them in the headlight housing. I got bulbs specifically for that.
Here
Zuhalter
<div class='quotetop'>QUOTE (Huzer21 @ Jul 9 2008, 07:40 AM) [url=index.php?act=findpost&pid=55583]<{POST_SNAPBACK}>[/url]</div>
Looks good. How's the auto dim look on the interior lights? Do they flicker, or does they still fade out like the stock bulbs?[/b]
Flicker on the dome light is minimal. You can see it in the day, but not at night. They also fade a little bit faster, but overall it is no big deal and I am happy with it.
Zuhalter
I should also note that if anyone is planning on replacing the blinker lights, be ready for some work. Installing the resistors and lights in the trunk is easy, putting them in the front is a PITA. You are working with limited space, limited wires, and overall crappy conditions! :P
Postby GR-8 » Wed Jul 09, 2008 9:14
<div class='quotetop'>QUOTE (Zuhalter Vati @ Jul 9 2008, 04:49 PM) [url=index.php?act=findpost&pid=55669]<{POST_SNAPBACK}>[/url]</div>
I should also note that if anyone is planning on replacing the blinker lights, be ready for some work. Installing the resistors and lights in the trunk is easy, putting them in the front is a PITA. You are working with limited space, limited wires, and overall crappy conditions! :P[/b]
Where did you go through to switch out the Blinker bulbs? Just curious, I went through the fender wells. Cranked the wheels over removed a few clips and did twisted my arm and got it that way. woulda been a lil easier to take the wheel off and the well covers all the way.
Postby Stealth01 » Wed Jul 09, 2008 9:14
<div class='quotetop'>QUOTE (Zuhalter Vati @ Jul 9 2008, 04:48 PM) [url=index.php?act=findpost&pid=55668]<{POST_SNAPBACK}>[/url]</div>
Flicker on the dome light is minimal. You can see it in the day, but not at night. They also fade a little bit faster, but overall it is no big deal and I am happy with it.[/b]
Mine are the same way -- dim with the dome lights very nicely.
<div class='quotetop'>QUOTE (Zuhalter Vati @ Jul 9 2008, 04:47 PM) [url=index.php?act=findpost&pid=55666]<{POST_SNAPBACK}>[/url]</div>
Here[/b]
Hmmmmmm......I may need to get some of those.
Zuhalter
<div class='quotetop'>QUOTE (Greek8 @ Jul 9 2008, 05:17 PM) [url=index.php?act=findpost&pid=55673]<{POST_SNAPBACK}>[/url]</div>
Where did you go through to switch out the Blinker bulbs? Just curious, I went through the fender wells. Cranked the wheels over removed a few clips and did twisted my arm and got it that way. woulda been a lil easier to take the wheel off and the well covers all the way.[/b]
I went in through the wells also, the only problem is that to get to the wires you have to go via the engine compartment, especially if you want to mount the resistors. It took a lot of time to get the wires, cut them out of the black wrapping, get the wiretaps to clamp properly and then have enough wire to pull it back in the sleeve and plug the blinker in. Over all I think it was worth it because it completes the look. The only disappointment was the yellow base of the LEDs which I didn't see while ordering them. You can't tell too much, so I will live with it.
cory.sparks
Postby cory.sparks » Thu Aug 28, 2008 9:14
I like that set up I was wondering if I install bright white sidelights would that be illegal in CO?
