Cobb Front Mount Intercooler for Mazda Speed 3
Those Meddling Kids
Postby Those Meddling Kids » Tue Jun 17, 2008 9:14
2007-08 MazdaSpeed3 Front Mount Intercooler Kit
Salt Lake City, Utah, June, 2008 - COBB Tuning is proud to announce the release of the all new Front Mount Intercooler
system for the 2007-08 MazdaSpeed3. Looking for an effective solution that will eliminate inconsistent power delivery from your MazdaSpeed3? Look no
further than the all new COBB Tuning Front Mount Intercooler. The factory top mounted intercooler can easily be over
worked and over heated due to its smaller size. In return, the intake air temperatures rise causing a loss in power. Replacing
the factory intercooler with the COBB Tuning Front Mount Intercooler will ensure that your engine is receiving the coolest
possible air, allowing you to enjoy more power that is also much more consistent!
One of the more common issues with a front mount intercooler is turbo lag. Our testing shows our core Inlet pressure
at an average of 15.45 psi and the Outlet pressure at an average of 14.8 psi. That results in an averaged pressure drop of
o n l y 0 . 6 5 p s i , w h i c h i n t u r n p r o d u c e s l i t t l e to no turbo lag at all! We also tested the cooling capacity of our core. With an
ambient temperature of 91 degrees, our Inlet temperature averaged 193 degrees F while our Outlet temperature averaged
9 5 degrees F. This is an averaged temperature drop of an unprecedented 98 degrees F!
 Bar and plate 24" x 3.5" x 7.9" aluminum core
 2.5" aluminum tubing powder coated dark Gray
 Blue silicone and t-bolt clamps
 All brackets and fasteners are included
 Some trimming of bumper tabs is required
 Made to fit stock BPV or aftermarket BOV that is stock fitment
 Retains stock bumper beam and does not require cutting the bumper beam
Engineered for maximum performance and precise fitment, the purposeful and aggressive looks of the COBB Tuning
Front Mount Intercooler will deliver pure driving pleasure! We recommend professional or experienced installation as the
fitment of the pipes needs to be specific to clear all places of the chassis/engine/transmission.
Part # 771600
Price: $995.00 plus tax (Everybody has to sell Cobb stuff at MSRP)
Hi All....I have one of these on order, first come first serve. Not sure when i'll be able to get more but hopefully soon. If you want dibs on it (It should be here sometime next week) then you need to call me and prepay for it. These are looking to be pretty hot, let me know, thanks.
Matt
Postby GR-8 » Tue Jun 17, 2008 9:14
Oooo fancy!
Postby movovr » Tue Jun 17, 2008 9:14
What would you charge for installation?
Postby Colombia28 » Tue Jun 17, 2008 9:14
:drool: man how i want that. Do you guys know if it is safe/ok to run this Cobb fmic without the AP or any sort of tune?
Postby TheNewBlack » Tue Jun 17, 2008 9:14
<div class='quotetop'>QUOTE (Colombia28 @ Jun 17 2008, 10:11 PM) [url=index.php?act=findpost&pid=52743]<{POST_SNAPBACK}>[/url]</div>
:drool: man how i want that. Do you guys know if it is safe/ok to run this Cobb fmic without the AP or any sort of tune?[/b]
I'm also curious about this ...and the install price.
MS3_Mafia
Postby MS3_Mafia » Tue Jun 17, 2008 9:14
It should be perfectly fine to have the FMIC without a Cobb Accesport.
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
^If that is the case i may be in debt soon :D
But which to get first? The AP or the FMIC? Which will yeild the most gains at first?
<div class='quotetop'>QUOTE (Greek8 @ Jun 17 2008, 11:47 PM) [url=index.php?act=findpost&pid=52778]<{POST_SNAPBACK}>[/url]</div>
But which to get first? The AP or the FMIC? Which will yeild the most gains at first?[/b]
Well this decision first rests on whether or not you need a tune (AP) to run the fmic without any problems (and i mean zero problems with AFR's ect ect). Im not in the market to harm my motor.
If you do not need a tune/AP to run the Cobb fmic without problems, it may be worth it over the AP because the power gained by the AP will still be limited by the stock tmic. The AP will yield more power than just the fmic, which is probably no power gain, but the fmic will get you more consistent and constant usable power. The fmic will do away with the MS3's period, ie. its finicky nature with its power. Some days its all there, some days its not.
<div class='quotetop'>QUOTE (Colombia28 @ Jun 18 2008, 12:08 AM) [url=index.php?act=findpost&pid=52785]<{POST_SNAPBACK}>[/url]</div>
......Some days its all there, some days its not.[/b]
Sounds like an 8. :lol: But there's no easy way to fix an 8 other than hope for a cold day.
<div class='quotetop'>QUOTE (Greek8 @ Jun 18 2008, 12:23 AM) [url=index.php?act=findpost&pid=52787]<{POST_SNAPBACK}>[/url]</div>
Sounds like an 8. :lol: But there's no easy way to fix an 8 other than hope for a cold day.[/b]
:lol:
Its strange i don't like cold days in the MS3. It feels slow when it gets to cold, a nice 60-74 degree day/night seems to be the MS3's sweet spot. But maybe the fmic will change the temp range to something a little more normal... like any temperature :lol:
Postby dommo_g » Tue Jun 17, 2008 9:14
Dear Cobb,
Is it too much to ask to NOT have almost 1psi pressure drop for our $1000.00?
Thank you,
MS3 owners.
Roadrnr06
Postby Roadrnr06 » Wed Jun 18, 2008 9:14
I am curious to see the data that supports this mod?
[/SIZE][/font]
Postby MazdaTom » Wed Jun 18, 2008 9:14
There are times when I like not having a turbo. $1000!!! Aye.
A .65 psi drop across the core is not that bad.
Postby Colombia28 » Wed Jun 18, 2008 9:14
<div class='quotetop'>QUOTE (MazdaTom @ Jun 18 2008, 07:53 AM) [url=index.php?act=findpost&pid=52813]<{POST_SNAPBACK}>[/url]</div>
A .65 psi drop across the core is not that bad.[/b]
Thank you. I don't understand what some people want from this world. Any drop in psi is not "ideal" but .65 i think is acceptable.
